How to run a wire from inside of a cab out to the back???
Discussion in 'Ask An Owner Operator' started by lights787, Apr 12, 2020.
  1. lights787
    lights787 Light Load Member
    118
    41
    Sep 26, 2019
    I need to install a rear dashcam on my trailer but to do so I need to be able to run a wire from dashboard to outside of the cab somewhere near the breaks/power lines. Has anyone done this to a 2015 international prostart+??? Can someone point me in the right direction?
    Thank you, drivers!!!
  3. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    If you want to be OCD about it, run it through a grommet in the firewall and squeeze it into a split loom that goes to your pigtail socket.
    Wasted Thyme and lights787 Thank this.
  4. Zigzag777
    Zigzag777 Medium Load Member
    460
    514
    Mar 25, 2013
    Down Yonder
    theSoz, Dale thompson, PE_T and 3 others Thank this.
  5. lights787
    118
    41
    Sep 26, 2019
  6. lights787
    118
    41
    Sep 26, 2019
    Where do I find that in the cab?
  7. p608
    p608 Road Train Member
    2,181
    2,992
    Nov 10, 2016
    Drill a hole
  8. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Open the hood and look for the wires going into the cab. Every hole is protected by a rubber grommet.
    tommymonza Thanks this.
  9. lights787
    118
    41
    Sep 26, 2019
    it needs to go out of the back of the cab going under the hood does not help me.
  10. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    You're missing the point. You go through the firewall and then under the cab. That's how the factory gets power from the fuse block to the switch and then on to your rear lights. If you look under the truck, you'll see every wire under there begins at the firewall, one way or another.
  11. Ridgeline
    22,605
    120,055
    no it don't I use wireless and they work very well.
