How to set ride height on a 2001 FLd 120
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Adamjorgy, Aug 16, 2015.
  1. Adamjorgy
    Adamjorgy Bobtail Member
    16
    My trucks I bought rides like crap bobtail and there's some vibrations and I'm pretty sure the ride height is off. I was told it needs to be set a 2 and 5/8 inches but can somebody one explain to me where I measure that from?
  3. Prom Night Dumpster Baby
    Prom Night Dumpster Baby Medium Load Member
    646
    473
    Jan 12, 2012
    Bug Tussle, TN
    You measure from the bumpstop to the bottom of frame.
    There's different measurements for the different way the saddle is attached to the axle, but my manual is from 1996 so maybe they were all the same by 2000.
    On mine I get slightly different measurements at each so I average it out.
    xsetra Thanks this.
  4. Adamjorgy
    16
  5. Adamjorgy
    16
    So from the bump stop on the top of the axle to the bottom of the frame? Any idea what that measurement should be?
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    my experience is the air bags should be low as possible for the best ride. not too low where the back end is lower than the front or there is a vibration from the bags being too low. if my air bags are about 1/2 way aired up the truck bounces like crazy, let some air out & the ride is so much more better. have to plat around to get it just where I like it.
  7. 062
    062 Road Train Member
    6,191
    33,375
    Oct 20, 2013
    You should be able to go as low as 2 3/8 without any driveline issues. Easiest way is make a cardboard template,I think measurement is at left front bump stop.
    xsetra Thanks this.
