how to shut off the idle shutdown on a 2015 Peterbilt with isx
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by canadianredneck, Mar 25, 2021.
  1. canadianredneck
    canadianredneck Light Load Member
    229
    104
    Jul 26, 2012
    Western Arkansas
    Good evening, I have a 15 isx 12 in a 15 peterbilt trash truck. Would love to get rid of the idle shutdown. Suggestions? i have insite
  3. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Go into the settings you’ll see idle shutdown I believe it is. I’ll have to open In -site back up snd check if you can’t figure it out.
  4. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,030
    Jul 12, 2017
    Features and Parameters- left column.
    Expand all
    Scroll down to Idle shutdown. Drop down arrow to change from enabled to disable.
    Right click on the setting and send to ECM
    Key cycle.......done.
    Heavyd Thanks this.
  5. Weking
    Weking Bobtail Member
    If that doesn’t work and you have cruise control, turn it on and once the brakes are set hit the set button on your cruise to raise the idle above 700rpm and it shouldn’t shut down
