how to spec a pto and pump
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by canadianredneck, Dec 14, 2015.
  1. canadianredneck
    canadianredneck Light Load Member
    229
    104
    Jul 26, 2012
    Western Arkansas
    Evening all. We are adding my olde water hauling truck to the fleet. It has a pto that runs a driveshaft to the now removed vacumn pump. I am trying to figure out how to size spec a pump to run on that pto to run the 8 car trailer we just bought. The 10 car has both an electric and PTO but not driveshaft style. The 6 car is battery operated on the trailer. Any ideas or suggestions would be appreciated.
  3. Hammer166
    7,553
    27,498
    Aug 18, 2007
    ~8600+' and loving it!
    Call the trailer manufacturer, they'll give you specs for gpm and psi. Look up the specs for your pto so you know what rpm the shaft will run, and you'll know which pump you need to order.
  4. canadianredneck
    229
    104
    Jul 26, 2012
    Western Arkansas
    I will, Thanks. Doesnt the GPM depend more on the tank volume? I have a 30 gallon tank I ran when hauling crude. it fits right where the vacumn pump went. I was hoping to use that.
  5. Cat sdp
    Cat sdp . .
    21,183
    75,084
    Apr 8, 2012
    Orion's Belt
    No gpm doesn't depend on tank size......if you return the oil fast enough you could still have a high gpm pump rate with a small tank.
  6. Hammer166
    7,553
    27,498
    Aug 18, 2007
    30 gals should take care of it. I don't think the factory tanks are even that large on the self-contained trailers.
    PSI = load capacity
    GPM = speed
    Plus, if your GPM is too slow, the cylinders have a greater tendency to want to work slightly out of phase.
