HPOP Pressure
Discussion in 'International Forum' started by yanni1474, Mar 3, 2012.
  1. yanni1474
    yanni1474 Bobtail Member
    4
    Spring Hill
    Have an 05 dt466 and when i test the hpop i only get 500 psi. When i deadhead the pump i get the same. It has a new icp and ipr.Need some help please!
  3. Heavyd
    Heavyd Road Train Member
    7,756
    6,195
    Feb 4, 2009
    If you are dead heading the pump correctly, and the pressure is only 500psi, you need a new pump. These pumps should hit 4000 before their internal relief valve opens. Pumps do go bad. Before you go any further, see if you set up some adaptors and apply 120 psi of shop air to the high pressure line going to the head. Listen for any air leaks under the valve cover.
