I am updating my trucks profile on the CARB website for the low use provision and it asks for my 'Hub serial number' along with my trucks 'PTO Hour-meter reading.'. I found the PTO HMR in my dash read out under the Engine Information category but can't find anything about HS#?
I tried Googling this but can't find any results. Thanks in advance for your help!
(Have a 2007 Century)
Hub Serial Number?
Discussion in 'Freightliner Forum' started by Dewey120, Dec 11, 2013.
odo. mounted on hub, is what they want # off of. PTO use keeps from getting had on idle time.
Dewey120 Thanks this. -
So where exactly is a hubometer at on a Freightliner Century? When you say hub is that the LED readout on my dashboard that shows my odometer reading? The only serial number I can find is DASH # A22-6109X-XXX and under that is SW # 2_2.1
I left it blank and CARB never said anything. I think they have bigger problems right now including the amendments they are voting on today. I think most people may be better off not reporting to CARB if you only have one or two trucks and run under 20% in CA.
