HVAC FUSE KEEPS BLOWING
Discussion in 'Ask An Owner Operator' started by Mae66, Apr 13, 2023.
  1. Mae66
    Mae66 Bobtail Member
    My 2006 KW T600 has been blowing the HVAC fuse the moment I start going down the road. Yet, while parked it runs perfectly. Worst part is I took it to the mechanic, of course it worked but the next day I'm back to square one. Any ideas
  3. Lazer
    Lazer Road Train Member
    1,790
    2,850
    Jan 22, 2017
    Is it the fuse to the blower?
    Is it the fuse to the compressor?
    Oldschool3400 Thanks this.
  4. roundhouse
    roundhouse Road Train Member
    3,169
    7,209
    Jul 11, 2018
    If it works fine sitting still but blows when you are driving , I’d guess the power wire going to the blower has a short that is getting grounded when driving due to the vibration of driving .
    First place I’d look is where the wire passes thru the firewall or somewhere the wire is close to some metal
    You own this truck or someone else own it ?
    if it’s yours ,
    You could bypass the bad wire and just run a new wire from the control to the blower .
    Start by unplugging the blower but turning it on at the controls
    that should put power on the wires
    It could be a short inside the blower motor itself .
    Opendeckin and LoneRanger Thank this.
  5. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
  6. FLHT
    FLHT Road Train Member
    1,382
    2,413
    Aug 2, 2014
    Front Blower or Sleeper Blower ?
    If you look on passenger side Behind seat half way up their is a plug under the sleeper to cab boot
    Check that the wires have not got hot and melted.
  7. Mae66
    It is the blower fuse that is going out. Thanks everyone for the help, I'm going to check into next stop since it's my truck and those mechanics charge way too much to not do a job correctly. Would go back to them but its several hundred miles to head back.
  8. roundhouse
    3,169
    7,209
    Jul 11, 2018
    You will need to just find the spot where the insulation has rubbed off the wire
    it will most likely be where the wire passes through the firewall or something , or at or near a connector plug or at or near where the wire is attached to the body with a P clamp. Or where the wire is rubbing on something , or where something is rubbing on the wire .
    it doesn’t take long for a airline or anything that vibrates to wear through the insulation on the wire .
    The controller for the speed of the blower , is also an area where this could be .
    I don’t know if your truck has an old fashioned controller with the resistors , or if it has the computer to control the speed .
    also check the blower motor itself
    unplug the blower from the harness , and go for a test drive ,
    If it doesn’t blow the fuse , then it’s Probabaly the blower motor or the wiring inside .
    I had one that kept getting wet and it wouldn’t operate properly
    I replaced the dash controls and replaced the electronic speed controller etc
    When it turned out to be the motor itself was damaged from getting wet
    I stopped the water from getting into the motor and it’s been fine since .
    start by unplugging the motor and do a test drive .
    If it still blows the fuse then you know it’s not in the motor or the plug at the motor ,
    So follow the wire harness and find the next connector plug and unplug it and go for another test drive ,
    If it still blows the fuse then you know it’s not in that section of wire so follow the wire and find the next plug etc
    once you narrow it down to which section of wire it is , then you can start looking for the damaged spot and repair it
    if you can’t find the damaged spot but ARE able to isolate which section of wire harness it’s in, then you can bypass the damaged wire with a new wire , or replace that section of harness .
    I have a vehicle that has a large connector plug thru the firewall
    And that connector just doesn’t always connect the wires
    I just isolated which wires don’t connect and bypassed the big connector
    I moved those wires out of the main connector and made my own connections
    drilled a hole on the firewall , inserted a grommet and passed the replacement wires through the grommet and used bullet or butt connectors .
