Hydraulic clutch brake not working.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by joe016, Apr 26, 2016.
  1. joe016
    joe016 Light Load Member
    120
    29
    Jan 23, 2016
    I have a 05 freightliner with a 10 speed it has a hydraulic clutch when I try to start out from a stop step on my clutch try to put the truck in gear I have to wait about 6 second before the clutch brake will stop the tranny so I can put it in gear had the clutch brake replace the old one had no wear but a new one same problem put a spacer between the clutch brake that work for about a month now back to the same problem clutch fluid is full and clutch is not adjustable anyone know what causing this problem it driving me crazy
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Many possibilities: How was the clutch brake replaced? Cut out and a two piece put in? How was the spacer installed, cut a section out of it and push it over the shaft? That can get yacked out and back to the same problem. Answer those questions as a start.
  4. joe016
    120
    29
    Jan 23, 2016
    Clutch brake was replace with a two piece . There was already a 2 piece clutch brake there that had no wear spacer was cut and push in I check in the morning and see if it still there . Why is the clutch brake not working I should not have to put a spacer clutch pull great no slipping
  5. joe016
    120
    29
    Jan 23, 2016
    This truck been nothing but a nightmare
  6. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    Those type problems often come from improper work during clutch replacement. The bushings and shafts in the bellhousing, ends on the clutch fork, and front bearing cover can be worn. Anyone or a combination of them can cause the problem you are talking about. There are some ways to make them to work in most cases without pulling the transmission. I have to go and maybe someone else can chime in, if not I will get back to you in a day or two.
  7. joe016
    120
    29
    Jan 23, 2016
  8. joe016
    120
    29
    Jan 23, 2016
    Could this be a wear out clutch causing this problem?
  9. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Yes, it could be a broken spring on your clutch plate, don't really know until you drop the transmission.
    Since you have to drop the transmission, you might as well replace the clutch.
  10. joe016
    120
    29
    Jan 23, 2016
    Figure that #### is there anyway I can put a banaid on it to last a little longer
  11. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    I looked for a post to refer you to but did not find it. Basicly the gap at the clutch brake should be a half inch with the freeplay held out of the pedal. Hydraulic with no free play, I don't know what to say. Space between the throwout brg and ends on clutch fork should be about 1/8 inch. Some times I have installed two clutch brakes of which some lasted for a long time. Anyone else input on this?
