I just passed my 100' foot backing/reversing, not a big deal.
We moved on to practicing the a 90 degree "banana dock" you start and go in a straight line through the marked area, then hard left turn stopping at a designated point.
at this point the truck is pointed to the left and the trailer is jacked. The instructors want us to then reverse back to the starting position.
You will either hold left to remove some of the jack in the trailer, or hold straight to increase the jack. I am having the worse time getting that trailer to go where I want it.
I either end up cranking left too soon/too late and end up with an oddly pointed trailer, or don't jack it and hit the right soft barrier(cones)
They said there is no formula, each time you do it its different, but for the life of me I cant seem to get it down.
Any advice? Maybe visualize more where I WANT the trailer to end up, that might help me back it into position?
I am having trouble with the 90 degree "banana dock"
Discussion in 'Questions From New Drivers' started by 2500HDRob, Apr 12, 2012.
Page 1 of 3
Are you trying to back in between cones? If so, start backing the trailer with a slight drift. Then start taking it back out. You want to get the trailer going at about a 45 degree angle towards the cones with both tractor and trailer in line with each other. Once you get about 20 feet out and 10 feet over from the first cone closest to you cut the wheel all the way right to jack the trailer left then go ahead and turn it all the way back left. The trailer with come back around and start squaring up with the hole. Once it does that start getting the tractor back under the trailer. You should be able to almost follow it in. May have to use one or two pull ups but they should allow two anyway.
Hope this helps. Also what works for one person may not work for you. Find the best way for you and stick with it. It will come. -
Practice, practice, practice. The alley dock seemed like the hardest to learn for me. It just took time to get it down. GOAL helps alot. I found it easier to not jack it as hard as it seems easier to get the trailer to jack more than recover from a trailer headed to the sight side (left) Just be paitient and keep working on it and youll get it in no time.
2500HDRob Thanks this. -
There are two guys in my class that can arc that thing right in the hole without any pull ups. I watched them and tried it. Never could get it to work for me so I went back to what was working for me and kept perfecting it. And still am. Practice practice practice. Only thing that will help you get better. And GOAL for goodness sakes even if it is only cones. You can be gigged for encroachment.
That two was my weak point. It clicked when my instructor (for lack of a better term!) used a toy truck and pulled it backwards into the spot so I could visualize how it needed to arc and move...then once in the truck, I kept my head looking forward using the mirrors primarily and only looking back over my left shoulder occasionally. That kept me aware of where the truck was in relation to the trailer and where I needed to be and I nailed it. Every time I just looked back through the window I would wind up all kinds of sideways!
Point the trailer where you want it and follow it in, not push it in.2500HDRob Thanks this. -
watch the trailer axle(s) as much as the trailer. that will be the pivot point when jacking...
A little wheel goes a long way when backing.
Stopping then correcting allows for corrections in much less distance.
Practice makes perfect they say, will let you know when I get to the point that it works perfectly and the same for me everytime
Keep at it, you'll be fine. -
Go slow...I mean idle back.....watch your trailer wheels........vision where your putting your trailer......be the boss and steer! Watch your back wheels, they determine where your trailer goes, dont watch back of trailer, watch your back tires. Don't be afraid to steer either, or pull up.
I appreciate the info guys, we start back on Monday and we get to practice it a bit more.
I do believe for our test of the banana dock we don't get any pullups as its set up where the cones simulate an alley So a banana alley backing? idk. It's a 5 point deduction to pull up.
Then again if 5 points saves me from getting more points not pulling up and subsequently messing up, I am going to take the 5. I'll still pass it. In the real world, you can pull up, but I understand why they want you to practice without it.
However, I am going to practice a lot more on Monday, and pray I get it down before we switch to a new exercise. I may ask to take my lunch period and practice it more as well.
Page 1 of 3
