I bought a truck with new virgin tires on the front/rear axle and worn tires on rear
Discussion in 'Trucks [ Eighteen Wheelers ]' started by midwestconnection, Jul 4, 2011.
  1. daks4s
    daks4s Bobtail Member
    9
    Crown Point IN
    I have found in one book that airing up the smaller doubles on one side of an axle 5psi more gives you a 5/16-inch difference in tire circumference
  2. Brandonpdx
    Brandonpdx Road Train Member
    4,260
    4,095
    Dec 27, 2007
    Elkhart, IN
    I think it's only a problem if you're driving around on dry pavement with the power divider locked for extended periods, which I have no idea why you'd do that anyway. In low traction situations the tires will scrub so easily that it shouldn't hurt anything.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    Match em.
    Virgin all around is what I would do. Once a year when the drives spun on first ice I would have shop get 8 new ones put on. Which worked out to 110-130K miles annually.
    Tolerances are pretty close these days and they need to match, the tires all around back there.
