i failed the alley dock for the third time! uggggh.....
Discussion in 'Questions From New Drivers' started by snowbird_89, Dec 8, 2009.
  1. snowbird_89
    snowbird_89 Road Train Member
    1,029
    826
    Aug 21, 2009
    Massachusetts
    on the first test, i passed everything except for the alley dock. on the second test, i failed the alley dock again. today i had my third test and i still failed the alley dock! grrrrrrrrr......:biggrin_25510: it is so frustrating. i didn't think i was gonna have this much difficulty. i'm gonna take a break from it for a while. maybe i'm just too overwhelmed by all the private lessons and tests i've been doing. maybe taking a break for a while will be good for me.
    i just have a hard time knowing when to turn the wheel right and left and how far i have to turn the wheel.. MA sucks to get your CDL. here, you're only allowed 3 get outs and 3 pull ups on each maneuver. 4 or more get outs/pull ups equals FAIL for the maneuver. also, if you hit a cone or cross the white line, it's an auto FAIL. i wish i lived in another state. :biggrin_2559:
  3. bordomzero
    bordomzero Light Load Member
    55
    10
    Sep 9, 2008
    Southern California
    all i can say is keep trying lol
  4. brinkj23
    brinkj23 "Asphalt Cowboy"
    1,165
    322
    Dec 26, 2005
    Minnesota
    do they have a time limit? if not go extremely slow, and remember slow easy corrections.
  5. ziggystyles
    ziggystyles Road Train Member
    I don't know if you have any ability to practice in a truck or not and get it down pat. I think an alley dock is where you have to pretty much do a 90 degree sight side back from a perpendicular position and you can't swing the truck out too far to the right.
    Here are some tips:
    *I don't think there is a limit as to how far you can pull forward...so if you want or need some more room to pull forward BEFORE you do anything else (ie..before you start backing and the dock is still to your 90 degrees left...you can pull forward). For example...when you are perpendicular and starting the manuever...see if you can pull forward a truck length or something. The more you pull forward, the easier it will be; because you can really start working the back of the trailer around that cone. If you start too far back...its going to a PITA to get that trailer around.
    *Keep in mind that the trailer starts to move slowly. You didn't say how you were failing the alley dock as far as are you turning too sharp..not sharp enough...etc? Trailers start off turning slowly but they whip around quite a bit fairly quickly as well...so if it looks like its not doing much....give it a second as you keep turning slowly into it.
    *you know that the truck will fit between the cones at the dock...so aim for the closest cone you can see on the drivers side of the trailer and try to get as close as you can do that as you are backing, because you know that if you get really close to it, you are going to clear the cone on the passenger side that you can't see.
    *you know you are getting 3 pull ups...so try to get the trailer as far back as you can, because the further you can get it back there without having to pull up, the better. The further back you are...the further forward you can pull up and make corrections.
    davetiow Thanks this.
  6. dairyman
    dairyman <b> Hopper Thread Greeter</b>
    1,223
    926
    Oct 31, 2009
    Ky.,wait'n in line
    danny_379,.. brinkj23 and ziggystyles gave you some good pointers,one other thing,what kind or trailer are you using,try to get a closed tandem with the axles all the way back that way you don't have to guess where the back of the trailer is so much,plus the moves won't be so drastic.hope this helps,hang in there,you will get it just don't give up!
  7. Truck Driver
    Truck Driver Medium Load Member
    330
    136
    Dec 5, 2007
    Sacramento, CA
    Well at least you'll get another try. Out here in CA, you'd be finished. You fail anything three times and you got to wait a year and reaply for your CDL.
    snakeskin Thanks this.
  8. rwings
    rwings <strong>"Jet Force"</strong>
    166
    55
    Sep 7, 2006
    Portales, NM
    Same rule here in New Mexico. However, here you are only allowed to GOAL once for each maneuver.
  9. snowbird_89
    1,029
    826
    Aug 21, 2009
    Massachusetts
    the truck i'm using is a single axle kenworth T-300. the trailer is 38 ft. long. i failed the firs two times because i crossed the white line. the third time was because i did 4 pull ups. but i was already in a bad spot because i didn't have the ICC bar of the trailer lined at the right cone when i started the maneuver. here in MA, the alley dock is a 45 degree angle i believe.
    http://www.mass.gov/rmv/cdlmanual/index.htm
    look at part three: section 11.
  10. jeepskate99
    jeepskate99 Road Train Member
    4 pull ups? Be glad you aren't in NY. 1 pull up and we have to parallel park it.
    Good luck next time
  11. snowbird_89
    1,029
    826
    Aug 21, 2009
    Massachusetts
    in MA, we're allowed 3 pull ups and 3 get outs on each maneuver. ####, in NY, you only get one pull up on each maneuver? are you allowed get outs? are you allowed to hit cones and/or cross the white line?
    no, MA doesn't have a time limit.
