I fear a blown head gasket
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jdb1997, Dec 18, 2020.
  1. jdb1997
    jdb1997 Bobtail Member
    6
    Dec 18, 2020
    I have 2015 Peterbilt with a Paccar motor. The radiator blew today and I am fearing the worst which is a blown head gasket. Can anybody give me an idea of what the repairs may cost at my Pete dealer including radiator and head gasket repair?
  3. AModelCat
    161,704
    What reasoning do you have that you suspect a head gasket?
  4. jdb1997
    6
    Dec 18, 2020
    I am probably thinking worst case scenario. I had a farm tractor radiator do the same thing and a blown head gasket caused it.
    Rideandrepair Thanks this.
  5. lester
    2,935
    7,940
    Jan 2, 2012
    NW, Iowa
    I know nothing of paccar engines but I'd say unless you had prior symptoms of pushing water out the over flow I wouldn't be concerned
    spsauerland and Rideandrepair Thank this.
  6. Rideandrepair
    17,451
    56,621
    Aug 8, 2015
    Well if your radiators leaking, you know you at least need a new one. I’d be worried too, since it’s only 5 yrs old. Unless you’re stranded far from home, and have no choice. I’d price radiators at the Dealer, and the aftermarket. Same with Labor. Don’t need to be a Peterbilt Mechanic to put a radiator in. Once it’s fixed, a simple pressure test, (which should be done anyways after installing a new radiator in a perfect world), will show any excessive coolant pressure build up. Go from there. Radiators from the Dealerships are almost twice as expensive than an aftermarket from what I’ve seen. They’re not any better. Just dropping it off, and letting them have at it can be costly. Especially when they start stacking jobs. Add miscellaneous shop fees, environmental fees, clean up fees, Red oval fees. Might be a good time to check the CAC, since it’s coming off anyways. If it’s leaking, the money you save can pay for a new one. Labors free.
    BoxCarKidd Thanks this.
  7. AModelCat
    161,704
    I seriously doubt you've got a headgasket problem. A lot of the rads these days are cheap aluminum and plastic pieces of trash. Where's it leaking from?
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    I had one blow but not a Paccar. Loaded uphill with my foot in a hurry. Started raining on a clear day ( water droplets on windshield ). Just cheep junk radiator I thank but changed the t stat also. No problems afterwards. Hope that works out for you as well.
  9. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    Pull the dipstick. If it's milky you have lost a head gasket. EDIT: Or you have a crack in the block. Had a 6.9 Ford Diesel do that.
    Rideandrepair and BoxCarKidd Thank this.
