I finally remembered to ask this question about trucks or trailers that lift their axles
Discussion in 'Experienced Truckers' Advice' started by TruckRunner, Apr 16, 2018.
  1. TruckRunner
    TruckRunner Heavy Load Member
    704
    3,270
    Dec 21, 2017
    You usually see this with trucks that pull oversized loads. You will notice that they may have one of their axles lifted off the ground so the tires wont be used. I always wondered are they lift up by air or do you have to crank the axle up? I assume it's the same for trailers too?
  3. Ridgeline
    22,524
    119,029
    Air. Some lift axles are tied to the controls of the suspension, other lift axles have a manual setup that you put up or down,
    TruckRunner Thanks this.
  4. Bad Monkey
    Bad Monkey Medium Load Member
    576
    367
    Jul 18, 2012
    Goshen, IN
    There were some old school tags that were spring up and air down.
    kylefitzy and TruckRunner Thank this.
  5. SteveScott
    SteveScott Road Train Member
    4,897
    16,808
    Nov 10, 2015
    I've been seeing them more often on new dry vans. I guess it saves wear on one set of tires and makes sharp turns easier?
  6. Ridgeline
    22,524
    119,029
    Old school is right. I haven't seen those in years, like 30 years.
  7. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    We have lift control in cab for lifting forward axle on 4 legged,,,lifts fore and aft on 5 legged. You want to be able to lift forward axle when road gets slick or lighten pressure.
  8. Long FLD
    Long FLD Road Train Member
    12,263
    50,713
    Mar 4, 2015
    I ran a spring up/air down until about 1999 because at that time they were lighter than the air/air axles that were available.
  9. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,522
    May 28, 2015
    Also less rolling resistance for much better fuel mileage when lightly loaded.
  10. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    They aren't needed when you're lightly loaded.
  11. DSK333
    DSK333 Road Train Member
    2,413
    2,756
    Jan 27, 2018
    Pennsyltucky
    They can save on the outrageous tolls all too many states like to impose on the transportation industry as well.
    KB3MMX, TruckRunner, rank and 5 others Thank this.
  12. mustang190
    mustang190 Road Train Member
    2,857
    6,143
    Jan 18, 2011
    Florida Panhandle
    Our new trucks and tankers that have tag axles work on a weight sensor. No load, axle raises by its self. Lowers when weight is added.
    LoneCowboy, Jazz1, TruckRunner and 3 others Thank this.
