I for the life of me cannot get my head wrapped around this problem
Discussion in 'Experienced Truckers' Advice' started by Matts28, Apr 28, 2017.
  1. Matts28
    Matts28 Bobtail Member
    28
    16
    Feb 8, 2016
    Virginia
    I've developed this odd habit of backing up to docks crooked. As in, I always bump the left side of my trailer and the right corner is about 2" off, resulting in a angled back. I made a little drawing. I'm wondering if it could be mirror placement throwing me off? I doubt the trailers are off tracking. They are brand new. Any help would be much appreciated!
      File size:
      21.4 KB
      68
    CallMeArty Thanks this.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,624
    18,299
    Nov 1, 2010
    Burnsville, MN
    If there is a line to follow on your left side, are you trying to make it look parallel with your trailer and drive tires in your mirror?
  4. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    Are you right handed?
  5. Matts28
    28
    16
    Feb 8, 2016
    Virginia
    Yes. I am lining the left side of the trailer up with the left line. When I get out and look, that's when I see that the right side is actually off.
    I am, yes.
  6. Kyle G.
    Kyle G. Road Train Member
    3,811
    19,933
    Jan 23, 2016
    Eastern Iowa
    I actually used to have the same problem. I eventually started making it a point to line up to where I thought I was straight, then overdo it a little so it would appear, in my mirrors, that the trailer is ####ed slightly to the left. Then I get out and lo and behold, it's straight as an arrow.
    C & C, AM14, Longarm and 1 other person Thank this.
  7. Matts28
    28
    16
    Feb 8, 2016
    Virginia
    Does that leave your tractor at an angle though?
  8. Maj. Jackhole
    Maj. Jackhole Heavy Load Member
    807
    4,202
    Mar 19, 2017
    Are you moving your body around while looking in mirrors? If so try keeping yourself sitting still swiveling head rather than body.
    sevenmph Thanks this.
  9. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    Usually doesn't matter, it can still be unloaded or loaded. but if you must, make the affort to change the angle
  10. Moosetek13
    14,624
    18,299
    Nov 1, 2010
    Burnsville, MN
    You have to consider perspective.
    What is far behind you, as in the rear of the trailer. should look closer to the line than your front end.
    When looking back in the mirror the line should not be parallel, but at an angle.
    Looking back in the mirrors the lines should look something like this...
    It is the reverse of what you see of the road in front of you when you are driving, which is...
    If you use both mirrors you will see the difference in angle very clearly.
    sevenmph, str8t10, DirtyBob and 4 others Thank this.
  11. 3031
    3031 Light Load Member
    178
    145
    Jun 29, 2011
    I've had the same issue. Eventually I just started compensating for it. No problems anymore.
