i hate the way desiel taste
Discussion in 'Peterbilt Forum' started by charleshilton150, Jun 25, 2012.
  1. charleshilton150
    charleshilton150 Bobtail Member
    Jun 25, 2012
    my 93 379 always runs out of desiel on one side never the same side depends on which lane i run i might have 75 gallons in one side and run out then i have to siffon it over cant find reason
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    You need to check the spliter and tank vents if all that chacks out I would run new return lines from the cyl head all the way back to the tank and make sure your crossover line is not tied up in the center higher them the tanks it should be a strait shot
