I have a Cat C15 serial prefix of MXS. What C15 do I have?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Deezl Smoke, Mar 10, 2018.
  1. Deezl Smoke
    Deezl Smoke Medium Load Member
    507
    330
    Feb 12, 2011
    Hillsboro Oregon
    It's in an '05 Peter 379X. C15 prefix of MXS with VVA. I've read several threads here about the C15's many configurations that are always referred to by the prefix. I also recall one of them being referred to as a "bridge" model C15, though I doubt the MXS is that.
    So what do I have here? A good model with some of the bugs worked out of the ACERT, or better yet, maybe prior to the intake valve thing? Was told current setting is 550hp.
    Truck has been ran.1.9 mill so far. Has never had a major, but has had rod and main bearings and every year the usual overhead and inspection. Says it burns a gallon every 10k. Blow by is virtually non-existant. The rest of this trucks life will be mainly bobtail or a small gooseneck rv.
    Just looking for any info you care to share as to what "normal" issues come up, or,....the good things about it would be nice to hear too.
    Thanks.
  3. AModelCat
    160,615
    MXS is an Acert.
    MBN is the bridge engine.
    6NZ is one of the best.
    SDP are junk.
    Oxbow and SAR Thank this.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Perty much. Lol
  5. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    Where does the BXS engine prefix fall into this mix.. MXS,MBN,6NZ,SPD.
  6. AModelCat
    160,615
    Not entirely sure. 6NZ was the earliest of the group I listed, followed by MBN. SDP was the last (newest) one IIRC.
    Oxbow Thanks this.
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    BSX's were the first Acerts, before the MXS and NXS. The MXS and NXS were pretty much the same. The BXS's had very different IVA setups though.
    Oxbow, Deezl Smoke, SAR and 3 others Thank this.
  8. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Keep an eye on your turbo studs. For as bad a rap as these motors get that's really the only issue I have experienced with the one I have.
    Oxbow, Deezl Smoke and SAR Thank this.
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,889
    May 31, 2010
    West Harrison, In
    BXS is easiest/cheapest to convert back to single turbo.
    snowman_w900, Oxbow, SAR and 1 other person Thank this.
  10. Deezl Smoke
    507
    330
    Feb 12, 2011
    Hillsboro Oregon
    So if I understand correctly, the IVA and VVA are basically the same thing. But the VVA might be an improved version?
  11. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,731
    Jan 30, 2010
    keep stroking.
    The bxs had add on vva's the mxs, nxs were one pc housings for the jake and vva's. The weak points. hold down studs for the vva/jakes, turbo studs for top turbo,harness for the precooler, high comp pistons= premature headgasket failure.
    snowman_w900, Oxbow, Expeditor and 2 others Thank this.
