I have a problem help please
Discussion in 'Questions From New Drivers' started by Redneckroy, Mar 10, 2010.
  1. Redneckroy
    Redneckroy Bobtail Member
    27
    Jul 20, 2008
    allons tn
    I probally made a big mistake in hiring on to a company just out of school that had AUTO TRANS:biggrin_25511: OK Lets get that behind me . I just when on a pre hire test and it was less than par. The school I paid big bucks for with " free retraining " is of couse missing in action. Now what ???????????:biggrin_25520::biggrin_2552::biggrin_25520::biggrin_2552:
  3. JustSonny
    JustSonny Big Dummy
    6,038
    5,786
    Oct 22, 2009
    Troutman NC
    Sounds like you quit the "auto trans" carrier, then did the prehire with another carrier. Is that correct?
    jtrnr1951 Thanks this.
  4. Redneckroy
    27
    Jul 20, 2008
    allons tn
    did not rehire went on pre hire road test. I sucked I have less than 2hrs behind wheel on a 10 speed they said My driving was very good I just need shifting experience. now what ??? I would go out with someone for a week for free-- but the only ones I know are in auto trans trucks--or could not take me
  5. red_eye
    red_eye Medium Load Member
    440
    123
    Dec 30, 2009
    belpre, ohio
    HEHE.. go back to US express :) .. JK.. I have always said.. auto's might be fine. till you want to drive a real truck.. then you have no idea how to shift..I really have no advice.. maybe try to find a OO an get him to take you out.. or see if the school will give you a refresher course on shfting.
  6. snowbunny
    snowbunny Medium Load Member
    531
    481
    Apr 17, 2008
    Ottawa, ON
    This might me naive...but can you go to the company that tested you..tell them, look i need to get the xperience shifting. Is there someone here willing to take me out and train me? I will go for a week, or two if necessary, free of charge! I am that dedicated and willing to learn! In return you will retest me when am done....if I pass great, if I don't you got 1 or 2 weeks of free labour....
  7. The Challenger
    The Challenger Kinghunter
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    You live in a good freight area where many will hire you. Why don't you try a different company?
    KH
  8. c.whited
    c.whited Bobtail Member
    go buy a streight shift car/pickup and train yourself.all shift patterns are the same -H
    then start off in 1st,thru 5.pull up the splitter,and start over.use the 5mph incurments on big trucks.there should be a diagram on the dash
    or sun visor,showing u the pattern
  9. Redneckroy
    27
    Jul 20, 2008
    allons tn
    hmmm no they dont train --kiss my a on us express-- I wanted help not retereck --and driven stick shift cars alot over last 30 yrs not the same you should know that its not patten its timing just need to get out there and do it just need a break to do that. read my post about free week
  10. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    You've got to relax. You know when the truck is going to shift from your other truck. Try to do the same but do it with less tension. When the engine and road speed are right the shifter will fall into place. If you miss the gear don't try to shove the shifter into that gear, just relax and go to the next lower gear. Don't over rev the engine and make the shift.
    The way it sounds the company you went on the pre-hire is willing to give you a shot when they say all you need is practice so what's the deal there? Did they say come back when you have experience or did they say they will look at you? If they are willing to hire you then don't worry because you'll get the training you need. If not then you have some good suggestions here on what to do.
    Years ago Cummins put out a booklet about progressive shifting when they introduced the new formula engines and they say to shift like this. Pick the lowest gear that will move the truck without applying any power. Run it up to 1250rpm and shift, run it up to 1300rpm and shift, run it up to 1350 and shift, run it up to 1400 and shift, run it up to 1450 and shift and so on. That's with a 10 speed and a 1900 rpm engine. You can adapt to other engines very easily just by increasing the rpm just a little with every shift. You don't want to run the engine up against the peg (the governor) and shift but you can run it up to about 100 rpm below the peg and shift. Of course up shifting is easy. Downshifting you'll have to really match the road speed with the engine. But again relax and if you miss the gear don't keep trying to make that hole and go to the next one lower. You'll get it over time and you'll know how to shift progressively, skip gears, and know what gear you'll need to be in for all speeds.
    The Challenger Thanks this.
  11. Redneckroy
    27
    Jul 20, 2008
    allons tn
    gashauler thank you :biggrin_25519: just need to find somewhere to get practice yes they want me back said my driving and driving hist is get just get practice.====:biggrin_25520:
