i have a water pump leak drip what is a fix that works but doesnt break the bank
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jings, Jan 11, 2018.
  1. jings
    jings Bobtail Member
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    A leak in the water pump itself?
    A new pump will do it.
    You could try patching but eh. That's not fixing the leak, just covering it up. You might regret such patching 100 miles from somewhere when it does fail again.
  4. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    Put a new pump on yourself.
    TripleSix Thanks this.
  5. Diesel Dave
    8,681
    24,685
    Jan 20, 2010
    Hesperia, Ca.
    Tap into your reserve. Your supposed to have one. Or didn’t you do your homework before you became O\O ? Like mentioned already, do it yourself and save a lot. Goodluck
    Oxbow Thanks this.
  6. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,293
    Sep 12, 2017
    Plymouth MI
    If it is an ISX, they make an O-ring water pump rebuild kit.
    Oxbow and Steel Dragon Thank this.
  7. 77fib77
    77fib77 Road Train Member
    10,476
    65,454
    Jul 7, 2010
    St Louis
    You don't know how many big companies have been taken down by faulty water pumps.
    Oxbow, AModelCat, Heavyd and 1 other person Thank this.
  8. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    No such thing as a mechanic in a can.
    The weep hole is there to alert you to the problem before your crack the head or burn up the motor.
    Oxbow and 77fib77 Thank this.
  9. 77fib77
    10,476
    65,454
    Jul 7, 2010
    St Louis
    $800 to pay someone to put it on and buy it?
  10. Steel Dragon
    2,681
    2,833
    Nov 23, 2015
    Easy job.
    Call around to local shops.
  11. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Do you pay by the word? No one here can help you based of such little information. Some smaller engines, you can change the water pump in less than an hour, some take 4-5 hours. Some like the S60's are known for plastic rear cover leaks and can be fixed easily with a metal cover kit. If you're asking if your water pump can be fixed or needs to be replaced, I have no clue, I don't even know what engine you have.
    Steel Dragon, Oxbow, SAR and 2 others Thank this.
