I have health problems. Could I still drive a truck?
Discussion in 'Questions From New Drivers' started by fentruck51, May 25, 2019.
  1. fentruck51
    fentruck51 Bobtail Member
    6
    4
    May 25, 2019
    I’m 31. 6’5 460 lbs. I take a lot of medicine for blood pressure (4 pills a day) I also take an anti depressant. I have sleep Apnea but I use a CPAP. Is there any company that will hire me with these health problems or am I out of luck? I’d love to work for Averitt. I live in Corbin, KY. Right on I-75.
    Chinatown Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    74,881
    170,618
    Aug 28, 2011
    Henderson, NV & Orient
    Only problem I see is the anti-depressant. Everything else seems to be under control.
    Can you quit the anti-depressant long enough to get established in trucking? Most companies won't hire you if you reveal the anti-depressant.
    Get a DOT Physical and find out if you can pass.
    CVS Pharmacy gives cheap ones.
  4. Chinatown
    74,881
    170,618
    Aug 28, 2011
    Here's a railroad job that requires a CDL-A.
    RJ Corman Railroad Services LLC - Nicholasville, KY
    Click here > Apply On Company Site
    Minimum Requirements
    • Live within 45 minutes of the shop (101 R.J. Corman Dr. Nicholasville, KY 40356 ).
    • Possess a current CDL A and DOT medical card.
    • Extensive travel is required.
    [​IMG].[​IMG]
  5. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Hey China do you see any of these jobs near Sacramento CA. That looks interesting
    HoneyBadger67 and Chinatown Thank this.
  6. fentruck51
    6
    4
    May 25, 2019
    My anti deprrssant is Citalopram. It’s supposedly approved by the DOT.
  7. Rideandrepair
    17,336
    56,249
    Aug 8, 2015
    Don’t mention anti- depressant, none of anyone’s bussiness anyway. Half the Country’s on them these days, truth be known
  8. fentruck51
    6
    4
    May 25, 2019
    Should I even mention any of my medicine, or the CPAP?
    Rideandrepair Thanks this.
  9. Chinatown
    74,881
    170,618
    Aug 28, 2011
    If that's the case, then all you need now is to pass the DOT physical. You'll get a 1 yr. card probably if your blood pressure is within guidelines while on medication.
  10. Chinatown
    74,881
    170,618
    Aug 28, 2011
    If you're that much overweight, you'll probably be sleep tested anyway.
    Try Stevens Transport since their trucks are set up with APU and will accommodate CPAP machine.
    www.stevenstransport.com
  11. Chinatown
    74,881
    170,618
    Aug 28, 2011
    DBI Services
    California Northern Railroad Company
    ~~~~~ @InTooDeep ~~~~~~~~~~~~
    Summary : DBI Services
    DBI Services, a global highway infrastructure maintenance company has openings for Hi Rail Operators to spray vegetation along railroads. Hi Rail Position requires a Class B CDL license and clean driving record. Operators must be willing to travel 4 to 6 weeks at a time and work overtime hours. Ability to work independently and some mechanical ability required. Must be able to pass the test for an Herbicide Application License. Experience driving a Hi Rail Truck a plus but will train the right individuals. We offer a competitive starting salary and benefits package along with the opportunity to be a part of a growth-oriented organization.
    SUMMARY: California Northern Railroad Company
    The person in this position works as a crew member to maintain, repair, and replace rails, ties, switches, and ballast. This person uses hand tools and operates heavy equipment. The position starts as a track maintainer, with an opportunity to qualify as a machine operator.
    InTooDeep Thanks this.
