I have no turn signal or hazzard lights
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jdb1997, Jan 23, 2021.
  1. jdb1997
    jdb1997 Bobtail Member
    6
    Dec 18, 2020
    When I hit the turn signal lever the indicators on the dash flash faster than normal like a bulb is our but I have no turn signals on the truck on either side, front, back or side. Same way when I hit the hazzard switch. Not a fuse. Signal stat or something else?
  3. 650cat425
    650cat425 Road Train Member
    1,548
    11,043
    Jan 26, 2020
    Pennsyltucky
    Working on the assumption that its a truck and trailer, have you unplugged the power to the trailer to attempt isolating the issue?
    Rideandrepair and D.Tibbitt Thank this.
  4. AKDoug
    AKDoug Medium Load Member
    323
    802
    Mar 21, 2018
    What kind of truck?. Sounds a lot like when my flasher relays go out on my 379, the other thing that jams them up is when the trailer plug has issues.
    Rideandrepair, D.Tibbitt and Bean Jr. Thank this.
  5. jdb1997
    6
    Dec 18, 2020
    It does the same with the trailer plugged in or not
    Rideandrepair Thanks this.
  6. Rideandrepair
    17,343
    56,259
    Aug 8, 2015
    First thing to check is the flasher in fuse panel. Taking it out, checking for loose or corroded Terminals. Second thing I’d check is turn signal plug. Unplug it, check wiring/ terminals, plug back in. For some reason, simply unplugging and plugging back in fixes a problem on the indicater itself. You could also unplug the pigtail at back of cab, to eliminate the pigtail as the problem. The next step along the same line, would be to disconnect the other end of the 7 wire at the fuse panel to eliminate it as a problem. These are things I’ve done on my WS and Freightliners over the years. You don’t mention what kind of Truck it is. Different Trucks, different common problems.
