i have replaced two starter in one week
Discussion in 'Volvo Forum' started by tone215, Oct 15, 2012.
  1. tone215
    tone215 Bobtail Member
    12
    philadelphia , PA
    I have a 2005 vnl 670 Cummings I replaced the starter twice. I just realized that the truck acts like its restarting while its on and thats why maybe the selinoid are going bad any ideas
  3. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Yes, you have the wrong starter. It has to be for a Cummins engine, the Cummings engines use different starters. Call Volvo and ask for the part numbers and see if they are different. Make sure you tell them you have a Cummings engine so they don't confuse it for the Cummins. Classic mistake.
    123456 and Heavyd Thank this.
  4. FozzyNOK
    FozzyNOK Road Train Member
    2,478
    3,820
    Jul 18, 2007
    Oklahomistan
    I see what you did there...
  5. tone215
    12
    philadelphia , PA
    It's the correct starter do u think it might be key ignition thats sending a signal
  6. bender
    bender Road Train Member
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    Low voltage will cause a starter to hang in after the engine is running without you realizing the starter is still running and grinding against the ring gear teeth. Check/test your batteries, all wiring/connections and your ground straps.
  7. tank4life
    tank4life Light Load Member
    155
    105
    Feb 18, 2012
    First thing to check is the grounds, always check the grounds, they will produce some strange symptoms. Also double check that your wires to the solenoid are not touching other posts, I have seen where they are close and when it gets hot it will contact one of the other posts on the solenoid and cause the starter to engage.
  8. aktundratugger
    aktundratugger Light Load Member
    126
    32
    Feb 10, 2012
    up on the hill, Ak
    just replaced starter because of bad battery voltage, one battery was bad.
  9. bossboy2
    bossboy2 Light Load Member
    264
    60
    Aug 20, 2011
    Houston, TX
    Did that solve your problem???
