I have two steer tires with diff tread depths~!! emergency or what?
Discussion in 'Questions From New Drivers' started by mikeposttown, Apr 17, 2019.
  1. mikeposttown
    mikeposttown Light Load Member
    78
    58
    Apr 17, 2019
    Hey my steer tire on left is 16/32... left is 8/32..
    when i make right hand turns on highway i feel it .. maybe pull some to the left.. steer weird.. sometimes "SLIDES" to the right .. during turn.. i get nervous going 65 hours plus and hit brakes on upcoming turns to take turns with no acceleration.
    Am i wrong to think this is a very big deal and needs fixed immediately with tires that have same tread depth and also at least 16/32 or more tread BECAUSE IF YOUR STEER TIRE BLOWS U COULD EASILY DIE AS IT WILL PULL THE TRUCK IMMEDIATELY TO THE RIGHT OR LEFT!! ETC
    The tires on steers should be around 5/32 or less around same tread depth size and preferably pretty new also i'd prefer as having a steer tire blow while driving would be like the ultimate worst thing that could happen almost i would think. Am i wrong?
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    It shouldn't matter if one has more tread than the other all else equal.
    Pulling and sliding to the right, probably is some other issue.
    It is never a good thing to blow a steer tire, but I have blown 2 in my life, with power steering it is notso bad, the first one was in an old cabover with no power steering, we went for a ride that time.
    Grubby, PE_T and x1Heavy Thank this.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,812
    18,697
    Nov 1, 2010
    Burnsville, MN
    I would be nervous going 65 hours plus, since I can't stay awake that long in the first place.
    And I do not think most steer tires blow because of tread depth. Most happen from sidewall failure or from running over an object in the road.
    SL3406, Grubby and OLDSKOOLERnWV Thank this.
  5. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    Trade that new one to an O/O for his half worn out one if it makes you feel safer.
    He'll probably split the mount/dismount fee with you if you ask nicely.
    SL3406 and Grubby Thank this.
  6. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,269
    Apr 19, 2018
    I had a cargo van and was doing the front brakes and was almost done and had it off the jacks and was tightening up the lug nuts when my brother came over and I got talking and completely forgot to finish tightning up the drivers side anyways about 3 days later it fell off going down the road , fortunately I was out in the boonies and it ended up a half a mile out in a field anyways it never shimmied or anything the lug nuts just fell off , but it really wasn't a big deal to stop and didn't do any damage
  7. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,141
    Mar 5, 2016
    White County, Arkansas
    Take a deep breath and say "no one is going to DIE today"
    When a steer tire goes grab a tight grip on that wheel, add power until she stablizes as you counter steer that enormous drag.
    Back off power slowly, speed will fall. Start looking for a spot on the shoulder where it will stop. Allow her to drift to a stop. No brakes, no jake no downshifting no wild man stuff. She'll stop.
    That's all you have to do. As long you don't screw that up no one will die.
    On the other stuff. You do have front end issues. Have a shop evaluate it. Swap both of those tires off your steers after you fix the front end issue. Old tires go to trailer spare pile. Put new tires on there.
    When we were a married team with FFE our 2000 freightliner Century was issued to us at 16 miles on the odo and we ran it on the orignal steers 221,000 miles. 10 months later we turned it in and the treads were in about 50% of life evenly. (Yokos...)
    That plus the brakes longetivity was a personal record The transmission not so much, it suffered a software bricking twice that year requiring a tow (Automatic, rockwell)
    stayinback Thanks this.
  8. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Always use slight acceleration in curves .. your hitting the brakes and coasting through them is likely to jackknife you one day on icy or slick pavement
    Grubby and Brettj3876 Thank this.
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Yep was gonna mention that. Get down to the speed that is safe for the corner BEFORE you enter the corner and gently accelerate throughout it. So many new drivers are not taught this
    Grubby, magoo68 and ncmickey Thank this.
  10. Brandt
    Brandt Road Train Member
    4,592
    6,305
    Sep 17, 2012
    You need an alignment and you probably find out why one tire is wearing more. You need a goo alignment like MD alignment, not the truck stop guys. They just do what the computers days and don't look to see what wrong. If you watch the video he talk about you problem one steer tire is wearing.
    Grubby and king Q Thank this.
  11. Ridgeline
    22,605
    120,051
    Within allowances.
    You are taking curves, not turns. I know it is nitpicking - been accused of that a lot lately but don't care, I like accurate information.
    If you are having issues with curves on the highway/freeway, it is one of four things;
    1 - the tires are not inflated right **which was never mentioned in any responses I saw
    2 - the truck is seriously misaligned, not just the steers but also the drives and possibly the trailer
    3 - the load is not properly placed on the trailer
    4 - the driver is new and not comfortable with the way the truck handles
    Yes you are wrong.
    Yes you are wrong, tread depth has to do with the tires' ability to adhere to the surface of the road. Other factors are involved with a blowout, primary the inflation of the tires themselves.
    Grubby and wis bang Thank this.
