I keep getting drowsy
Discussion in 'Questions From New Drivers' started by Steve C, Mar 31, 2013.
  1. Steve C
    Steve C Bobtail Member
    24
    10
    Jan 1, 2013
    Wichita, KS
    I'm about to start my fourth week of training. It seems like about 2/3rd's of the time I get real sleepy. I've driven very long distances in my car and never had an issue, but in the trucks I sometimes start getting drowsy within just a few miles. I've ridden with 7 different trainers and it seems like some trucks are worse than others.
    I used to get by just fine on 5 or 6 hours sleep. I've tried upping that to 7+ but that doesn't seem to help at all. I've also tried 5 Hour Energy without success. Some of my trainers are also nodding off when I'm driving. The company's trucks are either very new, or very old. It seems like it's worse in the really old trucks. Is there any possibility these have slight CO leaks?
    The only other thing I can think of is that I'm still pretty stressed out by training and that may be wearing me out. (although that doesn't explain why some of my trainers are falling asleep)
    Any ideas what's going on or what to do about it? Munching on sunflower seeds seems to help a little, but that doesn't seem like a permanent solution.
  3. rogueunh
    rogueunh Road Train Member
    1,086
    22,545
    Jan 4, 2011
    I would guess you aren't really getting enough rest. Being stressed out it can be hard to get quality sleep.
  4. WorldofTransportation
    WorldofTransportation Heavy Load Member
    702
    577
    Sep 20, 2009
    Your mother
    You are tired... your trainer is tired.... get more sleep.. If you suspect the truck is causing it through a co leak you need to find it during your pretrip.. If you are dot'd and they find it points and tickets will be issued.. If it is in multiple trucks though.............you need to get more rest.. If it is the truck doing it be glad you have Power Steering and air ride.. The ole days springs and non power steering was worse.. You will get it... and yeah most people don't last chewing sunflower seeds or chewing gum.. They turn to cigs or cheetos and either get hypertension or cancer... good luck... though
  5. muledriver
    muledriver Light Load Member
    270
    128
    Aug 8, 2012
    Well you are supposed to check the exhaust during your pre trip for that reason.It takes a little time to get used to trucking for long distances getting some entertainment besides what's on the standard radio stations helps me I have Pandora tune in and old time radio apps on my phone to listen to I dont drive tired and it surprises me that you have had trainers drive tired that's a no no . It might take a few months to get used to it as well .
  6. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,907
    51,671
    Dec 8, 2012
    hunting...../ retired
    It is not the truck...diesel engines don't give off enough CO to do you any harm at all.
    Can you get carbon monoxide poisoning from a diesel engine?
    This is possible, but unlikely. Diesel engines detonate fuel using pressure and temperature, rather than with an artificial spark. This process operates with excessive oxygen, ensuring a much more complete combustion than what is typical in a gasoline engine.
    Steve C Thanks this.
  7. Powder Joints
    7,949
    8,298
    Sep 25, 2007
    Rosamond, SoCal
    I drive for about 4 hours take a nap 15 to 30 minutes and I am good for 8 hours. The power naps works better for me than anything else. DO NOT DRIVE even if you think your DROWSE. Watch your diet try to eat a good balanced diet, carbs put you to sleep, sugars will make you crash 30 minutes later, eat balanced..... To many veggies will cause other problems.
  8. DirtyBob
    DirtyBob Road Train Member
    1,913
    1,628
    Sep 2, 2010
    Indiana
    You're probably just not used to the daily grind of doing it and you need more sleep. And like you said, the stress can wear you out as well. Once you get more comfortable with driving that will probably go away some.
    There are some simple things you can do to keep yourself awake and alert though. Keep your eyes up and looking out and check your mirros often. This is what a safe driver should be doing anyways, but when you start getting tired your vision starts dropping to a lower point and then you start fixating. That will make you even more tired. Fruits are great food for sustained energy, the sugar content is not too high or low. Don't eat large amounts of food at once, you get tired from digestion. Drink water instead of caffeine. Stimulants wear you down eventually and most drinks with caffeine are not good for hydration which your body needs. Try to find audio wise what helps keep you awake. For some it's listening to music, for others it's shutting off all music. For me, audiobooks keep me awake. Experiment with it.
  9. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    Perhaps you should consider reading up on sleep apnea. Here are some of the main symptoms;
    Excessive daytime sleepiness (hypersomnia)
    Loud snoring, which is usually more prominent in obstructive sleep apnea
    Episodes of breathing cessation during sleep witnessed by another person
    Abrupt awakenings accompanied by shortness of breath, which more likely indicates central sleep apnea
    Awakening with a dry mouth or sore throat
    Here is a link you may wish to review
    http://www.helpguide.org/life/sleep_apnea.htm
    Sleep apnea can affect anyone, regardless of their weight.
  10. goodchoice10
    goodchoice10 Heavy Load Member
    806
    422
    Aug 31, 2010
    The Buckeye
    no turkey before your shift.......................:biggrin_25525: (everyone else already said all the good stuff)
    Marksteven and Arenace Thank this.
  11. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I never heard of that before????? Please explain.
    There's a few things that can make you sleepy. Stress, inadequate rest, not use to changing up your circadian rhythm, boredom of long stretches of highway or letting your eyes get fatigued which will make you tired. Avoid looking at lights as much as you can. Dim your dashboard at night. The bright lights close your pupils putting a strain on them.
    Chewing on ice or gum helps.
    perufb Thanks this.
