I use to haul water with my truck so I had a challenger vacuum pump on it. I recently took pump off and started hauling belly dumps. Well my truck was short about a gallon of oil so I went into my shop and grabbed a gallon of oil thinking it was 15w 40 oil. After I poured it in I turned truck on and after awhile I noticed my oil pressure psi was at 60 to 70 when it regularly runs around 50. I hope I didn't but I'm thinking I put my vacuum pump oil in the engine. If I did will it hurt engine or anything else.
I need help! I accidentally put 1 gallon of vacuum pump oil into my engine. Will it hurt anything.
Discussion in 'Freightliner Forum' started by 96Freight, May 8, 2018.
If it’s gear oil it is pretty much the same as adding a gallon of Lucas .. I suspect pressure comes down a bit when it’s up to full temp .. I’ve added a gallon of gear oil to older engines with low oil pressure to bring it up a bit
Similar to oil used in air compressors. Non-detergent. Won’t hurt anything. A single gallon won’t make much of a difference.
If this is a newer truck, the emissions system may not like it. But won’t be catastrophic.magoo68 Thanks this. -
Gear oil is light years better than Lucas. Gear oil is made for high pressure, and has additives. It's cheaper I think to.
brysol01 Thanks this. -
I have used lucas for 40 years, unless none was available at oil change time. I have never noticed it changing my oil pressure.
Just curious old iron, what did lucas ever do to you, you must have had a bad experience with it?
