Please help. I have a 2008 Volvo VNL 670 with the automated ISHIFT transmission and volvo D13 engine. The problem is only with reverse when turning left or right or on a downhill. The truck will stop, move couple of inches and stop and it will repeat the process. When its on a flat straight line (no hills) there is no issues. I have no other issues or codes. I took it to Volvo repair shop, they inspected it and said there are no codes, they pulled the tranny out and driveshaft and can't find anything broken internally or externally. Could the problem be the differential? right now the truck has the driveshaft out and tranny out. I have no issues with the forward gears, truck shifts and downshifts smoothly. This problem has been with me for 1 year and i drove it like this with no problem until i got fed up of the problem.
I NEED HELP - VOLVO ISHIFT REVERSE PROBLEM
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ielfarra, Sep 24, 2017.
have same problem,, have you found out what was wrong with it
Has anybody found out what’s wrong I have the same issue on my 2015
Could it be the hill assist stopping the truck
L Stylz Thanks this. -
There is a switch on the dash for hill assist, try turning it off.
Mine was jerking in reverse and turned out to be a crack in the pressure plate on the clutch
I have a ishift need to sell 509k miles 2008 runs great came taking engine selling tranny i run 13spd
Hello.
I just saw you had same problem that I have now,with the reverse.
Can you please give me some help,tell me what I need to do, please.
Thank you
