I need help with trailer brake.I put pictures in it
Discussion in 'Ask An Owner Operator' started by Truck baba, Mar 3, 2023.
  1. beastr123
    beastr123 Road Train Member
    2,877
    23,601
    Jan 2, 2014
    Moose Jaw SK CAN
    This is probably the worse way to use your brakes.
    Using the trailer brake means that you are using 40% of your braking capacity and will destroy your trailer brakes by stopping 100%of your weight.
    The trailer brake is best used for protecting your unit in a slide on poor road surfaces by applying if the tractor slides and is starting to jackknife.
  3. J.R.
    J.R. Light Load Member
    64
    182
    May 17, 2012
    WI
    B S It's a tool, learn too use it. Just because some people are only able to master a hammer and pliers doesn't mean they are master mechanics.
  4. ducnut
    ducnut Road Train Member
    2,580
    7,774
    Dec 31, 2010
    SPI
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    We called it the ‘company jake brake’ if you were an o/o hauling for a carrier.
  6. Last Call
    Last Call Road Train Member
    7,568
    45,902
    Mar 15, 2021
    Theres times.. certainly not all the time I've used just the trailer brakes .. Especially if the roads are snow or ice covered... theres other situations also
    I guess I'am the odd duck cause I've never called it the trolly valve ..
    always called it the Johnson Bar
  7. buddyd157
    buddyd157 Road Train Member
    13,576
    34,885
    May 25, 2017
    under a shade tree
    true that be.
    in my earlier years, i had worked for for a division of NAVL (north american van lines) and NONE of thier company tractors, nor any of thier former O/O tractors (which were lease to own) had trolly brake handles for that very reason..and as i recall, any o/o that signed on with thier very own tractor?
    had to have the trolly handle removed, and that area "spot welded" if it was an all metal area closed up. or some sort of "glue" to cover up the area if it was a plastic area...NAVL meant business.
  8. AModelCat
    160,334
    Never heard it called either until I joined here. Everyone in these parts calls it the spike.
    cke, Vampire, Albertaflatbed and 4 others Thank this.
  9. Jubal Early Times
    3,069
    20,583
    Oct 17, 2022
    I really wonder where some of these people come from. Common sense really isn’t too common anymore.
    cke, Vampire, IH9300SBA and 5 others Thank this.
  10. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,058
    Nov 18, 2014
    Land of local
    I drew the short stick and had to train this goofy #### when I was doing cement for Schlumberger. Every time I had to remind him that when you step on the pedal all 5 axles are being used. He would pull on the trolley and use the foot pedal at the same time Lol. Every ####ing time, after a while I just didn't say anything.
    A few weeks into the job he hooked up to the wrong silo that was already full (they hold about 2.5 loads so you only put 2 in) and instead of stopping when the dust sock started filling up his ####### kept going. He emptied the rest of the load on the ground. We had to go clean it up and our 3rd party company was not allowed back on that company man's location. I can only assume his favorite snack as a kid was paint chips
  11. Last Call
    7,568
    45,902
    Mar 15, 2021
    Whats hard to figure out is .. are they really that stupid or are they just trolling ?
    I've come the the conclusion.. their just that stupid
    cke, Albertaflatbed, IH9300SBA and 4 others Thank this.
