I need help!
Discussion in 'Ask An Owner Operator' started by triaxlein, Jan 25, 2015.
  1. triaxlein
    triaxlein Bobtail Member
    Jan 25, 2015
    I just bought my first dump. She's old but runs like a champ 78 international 270 Cummins, 13 speed Eaton. Three stage, one way hydraulic. And thats where my problem lies.. the ram leaked at the second stage, and when i would lower the bed when it hit the second stage it was a little faster but then the first stage was normal, so didn't think much of it. Then I had the ram pulled off and repacked and leak was fixed problem solved, except when i dropped the bed the first time it dropped to the second stage and fell like a rock then grabbed the first stage and was fine.. any ideas what it might be
  3. wore out
    wore out Numbered Classic
    15,966
    193,273
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Sounds like air. There is a fitting on top the ram to bleed it. Best I remember you crack fitting and put her in raise till you get a good flow out of bleeder shut it down and tighten bleeder. It will prob. be easier with a helper
    ampm wayne and triaxlein Thank this.
  4. ampm wayne
    ampm wayne Heavy Load Member
    945
    746
    Jan 13, 2009
    bloomington,in
    I totally agree with wore out. You have air in it. It needs bled. Do not get injured doing yourself. I would get someone experienced in bleeding it to help you. Dump beds can be dangerous.
    triaxlein Thanks this.
  5. triaxlein
    Jan 25, 2015
    Thanks wore out and ampm. Thats what i was hoping for, nothing else really makes sense, lowers normal on third stage, drops like a rock on second stage and back to normal on third stage.... I'll try to get it bled tomorrow if I can and post results...
    ampm wayne and wore out Thank this.
  6. triaxlein
    Jan 25, 2015
    Oops...I mean back to normal on first stage!!
