I Need Loading Advice
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by MooneyBravo, Jun 24, 2017.
  1. MooneyBravo
    MooneyBravo Heavy Load Member
    856
    1,224
    Feb 20, 2012
    Vermilion, Oh
    I have a 2016 Volvo day cab.
    4 car Head rack
    High Rail
    Picking up 5 Escalades
    Lordstown to Pittsburgh
    I'm sure it's an easy load. Im just unfamiliar with that make and model.
    I also want to be able to see out the window so I was hoping to omit using the Head rack.
    I was thinking one on truck
    2 on the trailer with rear deck backed on
    Either 2 in belly or
    1 in belly, 1 pulled in the back under the other that was backed in.
    I have pockets on last deck on top of trailer.
    What do you think?
  3. SLANT6
    SLANT6 Road Train Member
    1,094
    1,376
    Dec 3, 2012
    The Nut House
    I'd drive 2 on the Headrack, 2 on the top deck of Trailer, and 1 in the belly. any other way you're working a lot harder than you have to.
    Tropsnart, Banker and MooneyBravo Thank this.
  4. Hammer166
    7,575
    27,616
    Aug 18, 2007
    ~8600+' and loving it!
    The other way to do it is one on the headrack, #3, split deck #4 & #5 (backed on), one in the belly, one on the tail. Leave the tail as far back as you can. There's long and short versions of those, save a shorty for the bottom back, and top back if you have another.
    MooneyBravo Thanks this.
  5. Banker
    Banker Road Train Member
    4,352
    13,384
    Aug 19, 2012
    This is exactly how I would do it. I always drive #1 on when possible because it makes a difference in fuel economy. I bought longer straps so I can leave a short suv back a foot or so from the stops by using an extra idler. Basically I drive it just far enough to be able to drop the back tires down to near the frame. #3 I drive on just past the point to open the front door, split deck. 4 it doesn't matter with only 5 units.
    If you were an owner op on this load you would be hauling 6 legally. 4 would be backed with front tires dropped in pockets and 6 would be driven on below it, looks like a big "V" 5 backed in belly, the unit over it won't be 12,6.
    Tropsnart Thanks this.
  6. MooneyBravo
    856
    1,224
    Feb 20, 2012
    Vermilion, Oh
    Thanks
    So I would drive the first one on and split it between DEC 2 and the head rack keeping about a foot behind the head pockets?
    Drive #2 on swing deck
    Pull 3 on to open door
    4 on tail and 5 in belly?
    Banker Thanks this.
  7. Banker
    4,352
    13,384
    Aug 19, 2012
    In order to drive 1 on and stop short you will need to add an extra idler on each side or use portable straps. But this is what I have found to keep height down and weight off steers. A long unit like a suburban doesn't have to stay as far back, but a short Tahoe has to stay back in order to get the height down.
  8. Banker
    4,352
    13,384
    Aug 19, 2012
    Correct. Leave about a foot gap between 2&1 decks so back tires sit on porch and hooks in fourth hole with plenty of slack on 2 deck.
  9. SLANT6
    1,094
    1,376
    Dec 3, 2012
    The Nut House
    Driving on #1 on the headrack not only helps fuel economy, but I have seen rear glass blow in on SUV's and P/U's. They were not designed to go 70 mph in reverse.
  10. skinnyb01
    skinnyb01 Light Load Member
    154
    212
    Feb 7, 2016
    uhaul moving blankets save windows. It's not %100 protection but it's been a while since I blew out a back glass. For the $15 for a bag of four I don't even wash em anymore
  11. sxdime
    sxdime Medium Load Member
    409
    551
    Nov 9, 2010
    Elkton MD
    Also those GM suv's the mirrors don't like to stay folded in if they aren't power folding ones. Watch the placement of that or they can create a problem.
    LBZ, brian991219 and Hammer166 Thank this.
