I Quit (if Roehl had an exit interview it might have gone like this)
Discussion in 'Roehl' started by Oldguynewjob, Oct 28, 2010.
  1. Oldguynewjob
    Oldguynewjob Light Load Member
    96
    36
    Oct 7, 2008
    Il.
    Roehl H.R.
    So Oldguy what drove you to quit after over two years with the company?
    Me
    Four major problems, miles, fighting to get home, running east most of the time (I live in northern Il.) and maintenance problems.
    Roehl H.R.
    Can you be more specific, (ho hum like I realy care)
    Me
    Sure, lets start with miles.
    I'm on national van out 11 home 3 and most outings I total between 3,500-3,900 miles. As you can see I have many checks in the $300.00
    range.
    Then there is fighting for home time.
    About 8 weeks ago on a Friday I was to relay a load at Gary and head for home, sounds great. I had just sent in my dropped at relay and wasn't even parked when I received a load plan to pick-up a relay at Gary and take it to Central Wi. for a late Saturday morning delivery. I called my F.M. who wasn't available and was told by fill in FM that I must take this load and could head for home when empty. After delivering the new home load I was about an hour south when I received a load plan to live load south of Madison Wi for a some day delivery to De Kalb Il. When I called the weekend F.M. he went to great lengths to tell me how hard Roehl works to get drivers home, and how lucky I was to drive for them. He must have laughed his ... off after he hung up thinking I belived his line of crap. I delivered the load with two hours on my day, just made home late Saturday night. Two weeks later I drop a relay at Gary for home time, have to set for two hours waiting for an empty only to have a flat on my drive tire. I write up the flat and check with maintenance, one truck ahead of me, check back in an hour, three trucks ahead of me ( since I am not under a load all loaded trucks go ahead of me) check back at 21:00 (I am now out of hours) eight trucks ahead of me. At this rate I would never see home and no one was there with the power to override the system, so I asked to be removed from the list and drove home in the morning with the flat feeling guilty all the way home. Tuesday morning at launch I called breakdown with a flat tire and was sent to a tire repair place that took 45 min. for complete repair (the tire was O.K.). Two weeks later sent to Cottage Grove on Friday to drop a relay and head home. No empty trailers so I called FM who was not available and was given Katie to help me out. Katie says I should not go home (70 miles) bobtail but should wait for an empty, she told me she would E-mail planner as they did not answer her call as to a location of an empty. When I told her it was urgent to get an answer from the planner as I was running out of hours she sternly told me she would not be rude to the planner. When I called back an hour later and asked for Katie I was told she had gone home and nobody seemed to know about my problem (seems she was rude after all). An empty came in at 02:30, I hooked it and went home later that morning. Launched the following Tuesday with a deadhead right back to Cottage Grove to pick up a relay.
    Head East (not the rock group)
    I almost always go east with a run through New England most outings. I have not been to Denver ,Salt Lake or beyond in almost a year. Even if the 80% of Roehls freight goes east I should still go west 20% of the time.
    I do seem to get to Canada a lot but thats not a good thing either.
    Maintenance
    While my truck had 550,000 it still was a good truck. It did have an engine problem that caused it to cough and puke black smoke when under a load. The problem grew steadly worse over the last year but every time it was in the shop the tecs would tell me there was no code in the computer so there was no way to fix it. By the time I turned in the truck it was coughing almost every time it had to pull under acceleration or on a hill.
    One time my truck had a turbo problem ,and when I called breakdown and told them I could hardly go 45 MPH they told me to check the oil and water, then asked if I could make it to a terminal almost 500 miles away. I had to almost yell into the phone that the truck was unsafe to drive and that I was not going anywhere but to a shop for repairs.
    Roehl HR
    Gee Oldguy you certainly complain a lot, you probably weren't a good employee anyway.
    Me
    In over two years I never had a sick day ,was never late for a launch, had only one service failure (miscalculated travel time totally my fault) was less than an hour late. I have several MPG quarterly bonuses, and just received a two year safe driver award.
    Roehl HR
    I really must be going, I have 8 school grads and about 15 drivers fresh out of orientation fighting for your truck.
    So ends my time with Roehl, the company could be so much beter with just a little concern for its drivers, but I think management wants to be just like the other big trucking companies.
    Good luck to all who still work for Roel and the power of faded red.
    HFC, Everett, mycorky and 2 others Thank this.
  3. ETCH5858
    ETCH5858 Medium Load Member
    605
    371
    Feb 25, 2009
    I can relate and I am sorry to see you go. What I realized in over 2 years with Roehl was enough to make me question the company and leave. I found that even on the O/O side of Roehl the DSR's always played the you are lucky to drive for Roehl card. I think they really don't know any better. Most of them live in tiny Marshfield and alot of times it is really the only job they have had. Many do not understand the trucking industry and only know the Roehl way.
    What they don't understand is that Roehls freight base is amoung the worst of the major larger carries. Thier equipment is old and worn out and thier pay rate is actually quite low. It took me nearly 3 years to put the puzzle togeather and I am so much happier now that I left.
    There are alot of positive things on this site about Roehl. Most if not all are by drivers with less than a couple years experience. If Roehl is the only company you know then it may not appear so bad. They have taught drivers that it is a priveldge to go home, even if it's late They have tried to teach drivers per diem is great. They really like to show they are being generous by paying drivers under .30 cpm. The drivers that stay begin to see that theppower of red is really a illusion. Dedicated and regional is the future of trucking and Roehl is really missing out on this. Roehl for the most part hauls secondary quality freight and hauls alot of broker loads. That means they haul alot of stuff other carries just wont haul. Roehl figured it would be better off by going to a flat rate charge regardless of weight. Now roehl freight has gotten much heavier and harder to haul. As a O/O I found I was spending so much more on fuel just hauling thier freight.
    It was time to go. If trucking is your career Roehl may be a decent place to start but for the long term it is horrible. There is way more money to be made and better programs at so many other carriers. Is Roehl really hiring all these students because they love helping people or have they found a way to make more profit at a drivers expense? Companies only exist to make money, you are only a tool that they need in order to achieve this goal. Roehl IS NOT your friend.........
  4. jeepcreep
    jeepcreep Bobtail Member
    7
    nw, WI
    I quit roehl about a month ago, money was the big issue with me. I was on the 7/4 fleet but started out nat van. I have small kids and realized home time was more important than I originally thought. I was only there for 4 months and found a local job that pays hourly. Now I make more and I'm home every night. I was very fortunate to have excellent fleet managers. I had a few issues with breakdown but turned out fine. towards the end I did have mostly heavy loads and rarely met my mpg goal. Earlier last summer I had a few weeks with most loads under 20,000. I spent alot of time sitting on nat van but rarely on hometime fleet. My checks didnt werent much different but only averaged $300, not enough for being gone that much. I wish everyone luck:biggrin_25525:
  5. spinpsychle
    spinpsychle Medium Load Member
    422
    68
    Oct 29, 2008
    New Brighton, MN
    If Roehl conducted exit interviews the interviewer would be bored, quite as you've suggested he would be. Mainly because it's all the same things I said during mine, and Etch said during his, and Smiley said during hers, and I forget where JoeDuno is now, and a bunch of others.
    I don't mind the northeast, as long as I'm not dispatched into a situation where I wouldn't have the hours to find one of their elusive parking spots. Of course nowadays I'd just run till I found one anyhow.
  6. mycorky
    mycorky Light Load Member
    107
    27
    Aug 31, 2006
    Illinois
    As I said over a year ago...Roehl has become a training school trucking company...and does not care about the people who come there to work. The only good job there is as a trainer...they never run out of work! :biggrin_25523:
    Debby
  7. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Big companies are never the answer.
    Too bad none of these new guys ever take it to heart when I say it.
  8. rambler
    rambler Road Train Member
    1,358
    582
    Nov 5, 2007
    Its sad to know there are companies out there paying 300-400 bucks a week. :biggrin_25513:
  9. JimTheHut
    JimTheHut Road Train Member
    3,983
    2,164
    Sep 26, 2009
    Central Ohio-Go Bucks!
    If I had a 3900 mile week, my check would be $1,599.00
  10. spinpsychle
    422
    68
    Oct 29, 2008
    New Brighton, MN
    I believe he said 3,900 miles in 14 days.
    JimTheHut Thanks this.
  11. hindsy
    hindsy Road Train Member
    1,489
    518
    Mar 23, 2010
    USA
    As one of those "new" drivers I will only agree that this is a way for them to profit. It served a purpose for me that would not be possible without them. I'm grateful for that, but have seen some of the issues you both have brought up. Etch I really don't think that any of the Companies are really your friend. But I see what you say.
    My goal is to make it the year then evaluate other issues... As rough as my start has been I think it will not be a problem. Heck if I get 3900 miles in two weeks its an improvement... lol
