Hi everyone i have a horrible experience i have a code mid 130 psid 232 fmi 9 that is code for bad communication between transmission and ecu,iv been trying everything and no one couldn’t find problem , we even replaced with different transmissiona and a new transmission ECU , same code, checked wiring between transmission and engine and engine and truck CAN, everything is looks good, transmission is just going in safe mode and stops after 300 miles even the new transmission we try! Thats just crazy....
I shift mid 130 psid 232 fmi 9 need help!
Discussion in 'Ask An Owner Operator' started by igorkoua, Dec 14, 2017.
Page 1 of 4
If no one COULDN'T find the problem then obviously everyone COULD find the problem.so theres no problem. Only solutions.
Bad harness. Looking good and ohming out are two different things. Possible bad new computer. Stranger things have happened.
What's trans temp.like?
My friend we did all of this my electric did ohming all wires betwen cab en engine and between transmission , all even abs block, we try new computer connect still that dam code, the temperature and air is normal, like i said we installed new transmission and tested same problem, its just nightmare
MID 130 Volvo Gear box fault codes
PSID 232
CAN data signal power unit.
9
The pace and frequency of data updates, are wrong. -
Please tell me were to look next((((?
That would be up to the mechanic... If they are qualified and a factory trained technician then they should know. If you are doing this on your own, then suggest you get ahold of a service dealer for Volvo77fib77 Thanks this.
Volvo doesn’t tell nothing same as those “qualified” mechanics! Please read first post we checked and tried all that staff maybe with forgot to check something..
I am only telling you want that code means... I am not a Volvo Technician. I Googled the code..
Page 1 of 4
