I suspect my company swapped engines. Is it possible?
Discussion in 'Ask An Owner Operator' started by Forever237, Jun 2, 2019.
  1. Forever237
    Forever237 Light Load Member
    122
    63
    May 29, 2016
    Hello Fellow Truckers,
    I have 2018 with 120K miles Volvo 780.
    Ok, so I park my truck at my company they have a shop and I didn’t work the month of March (26 days). After I started working i noticed MPG fell down.
    So middle of May I did overhead adjustment at a dealership and asked them why my MPG fell down. The did the adjustments and hooked the engine to the computer and came up with 17% idling (that is 2 hours of idling a day if you drive 11 hours). One thing I don’t do is Idling. I avoid it even if it is 5 mins.
    So now I have this eerie feeling maybe the engine was swapped. The company has fleet of trucks with same D13 engines.
    So my question is whether it is possible to swap it and cover the tracks?
    If yes what places I should look for telltale signs?
  3. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    All I have to say is WOW.
    It would be hard, almost impossible to swap the engine and not be easily detectable.
    Does the mileage on your ecm match the truck?
    PE_T, AModelCat and Oxbow Thank this.
  4. odds are somebody used your truck unless you own it outright! even if it's a lease purchase they can put anybody in that if they want. if somebody's truck was in the shop and they needed to use it odds are they probably let somebody use it said here use this this guy's gone go deliver your load so who the heck knows that's probably what happened I don't think there was any kind of an engine swap at all..
    I would check the ECM miles versus The hub miles what were the miles when you parked it does it look like there's added miles out to the odometer ?Bottom line is unless you possess the title "even if it's a lease purchase truck" they hold the lien they can let anybody drive it if they want to if it sits for more than a week probably what happened there chief
  5. JonJon78
    JonJon78 Road Train Member
    7,207
    42,197
    Jul 1, 2018
    The D13 doesn't have a plate with the serial number on it?
    AModelCat, Tb0n3, spyder7723 and 3 others Thank this.
  6. Chinatown
    Chinatown Road Train Member
    76,739
    178,617
    Aug 28, 2011
    Henderson, NV & Orient
    That wouldn't be the first time something like that happened.
    I once worked for a company that had one of their engines get ragged. The owner bought a new truck on credit then swapped the engines and let the new truck be repossessed.
    Seems with the newer truck it would be easy to know since everything is computerized.
    @Ridgeline probably knows how to figure this out.
    Tombstone69 and Intothesunset Thank this.
  7. Forever237
    122
    63
    May 29, 2016
    Like i said dealer did all computer work and didn’t say anything about not matching. This is just me being suspicious or maybe overly suspicious. Just wondering if that’s possible.
  8. Forever237
    122
    63
    May 29, 2016
    I record the milage every time I leave it at the parking lot so i’m sure they didn’t drive it and on top of that truck is under my company name and has nothing to do with this company.
  9. Forever237
    122
    63
    May 29, 2016
    Where should i look for vin? Is it engraved on engine block?
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,140
    Mar 5, 2016
    White County, Arkansas
    It's possible. But a straight swap? You would know it the minute you started her.
    Other drivers in it? Certainly. Always comes back with a problem. My last one had it for three days and turned a perfect truck condition in terms of shop needs from 100% into a list of problems needing two days TLC in a shop.
  11. JonJon78
    7,207
    42,197
    Jul 1, 2018
    I have a Cummins and its located on the drivers side. I would be surprised if a D13 didn't have something similar... Heres an example of Cummins 20190410_114928.jpg
    Forever237 and Intothesunset Thank this.
