i think i srewed up my transmission
Discussion in 'Questions From New Drivers' started by TheRedskinsWay, May 26, 2012.
  1. TheRedskinsWay
    TheRedskinsWay Light Load Member
    174
    36
    Mar 11, 2011
    Columbia SC
    I was in Wilmington, De and hit two huge potholes. I hit the potholes at 45mph at night, now these stupid holes didnt have cones or a metal plate over them they blended perfectly in the dark. After that happened i was stopped by a stoplight. on green i noticed as i accelerate the stick started to move in a upward right motion and like the stick is trying to come out of the floor,then the clutch makes a pop noise when im starting from 0 , the stick will move weird like that untill i get into the high gears(8speed). after i dropped the load off in new castle i didnt noticed nothing at all. I then picked up a new load at P&G in Dover and noticed the weird stick motion and popping noise all over again, so it only happens when im loaded or sliding my tendems. What is this?
  3. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Possibly broke a motor/trans mount or worse a spring or frame. But I doubt either of the last two.
  4. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Yup, engine or transmission mount. Fix it ASAP, or you'll put a fan blade through the radiator.
    -MadMax- and MNdriver Thank this.
  5. Ruges
    Ruges Light Load Member
    190
    70
    Feb 6, 2010
    InMyTruck, USA
    I'll go ahead and third this thought. But add in just looking at the mounts to see if they are broken will tell you, somtimes they have to be lifted to see if they are broken. Whats happening to you when the shifter is jumping around is the torque from the engine is causing the engine and transmission to roll over.
  6. -MadMax-
    -MadMax- Light Load Member
    248
    72
    Feb 29, 2012
    Pennsylvania
    I know in a 4wheeler you can SEE the motor lift if a mount is broken. Actually, if you gas(fuel) it a bit and then let off, and feel a "bump" then that could be the engine lifting then sitting back down into the mount.
    I've had this problem on a couple of different 4wheelers.
  7. Diesel Smoke
    Diesel Smoke Bobtail Member
    44
    7
    May 21, 2012
    Atlanta, GA
    I'd have a professional look at it, sounds to me you broke a transmission bracket/mount. As the stick moving hints a problem with the transmission's position on its brackets/mount. Pretty much I'm backing what Windsmith said.
  8. 48Packard
    48Packard Ol' Two-stop Shag!
    8,348
    9,871
    Apr 19, 2009
    Could be anywhere
    Yep...I....one, two, three, four.....fifth it. The stick is moving as the trans is torquing under acceleration.
    Either way...that's-a not good-a.....
  9. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Do you float when you shift?
  10. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    If it is engine mounts, lift the hood and do a tug text with a trailer. Forward and it hops, it is the left mount. Reverse and it hops is the right.
    Be careful though. As mentioned, the engine and fan move. The radiator and fan shroud do not!
    Mikeeee
  11. TheRedskinsWay
    174
    36
    Mar 11, 2011
    Columbia SC
    I float.
    Did that, nothing seems like anything is moving. also checked any bolts, brackets, mounts, even screws and dont see nothing cracked or broken. Its also fair to say im not really smart when it comes to type of stuff.
    thanks guys for all the help!
    NDBADLANDS Thanks this.
