I turned my Windows laptop into a Linux laptop, easy.
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by tscottme, Oct 20, 2025.
  1. tscottme
    tscottme Road Train Member
    On Oct 14 Microsoft stopped keeping Win 10 updated for security. I didn't want to continue in the Windows and the Apple "no privacy" ecosphere so I looked into using Linux. Linux is made with security in mind from it's invention until now. It leaks a lot less personal info to advertisers. This converting my laptop from Windows to Linux was the easiest computer project I've ever done. My ancient laptop runs like new again. Linux doesn't demand nearly as much from the PC running it as Windows.
    I had to create a bootable USB thumbdrive, the Linux people show you how and it's easy.
    Then I replaced my hard drive with a new $30 replacement 1TB drive.
    Then I plugged in the USB drive, turn on my laptop and followed the prompts to pick my language and time zone.
    The last time I worked with Linux was 5 or more years ago where I bought a Raspberry Pi and created a home movie server. All of the commands and programming was done by the command line. It was not fun. That is NOT what Linux is anymore. You can do that if you want. Everything I described above was done with Windows like pointing and clicking with a mouse. I use a flavor of Linux called Ubuntu, not sure how to pronounce it. It's the biggest, most stable, and most supported (meaning easiest to use to get answers about) version of Linux. I made my decision for ease of use and installation. There is another very easy to use version called Mint. And another version which is aimed at former Windows users and seeks to replicate Windows user habits to make life easy.
    Ubuntu doesn't cost anything. You don't have to make a new account to use it. I have my documents, browser settings, bookmarks, password manager, email, everything I wanted to preserve on my "new" laptop working as expected and it took about 1 hour to make it happen. The hardest part was waiting for my new hard drive to show up from Amazon. Using a new hard drive allows me to keep the old driver exactly as it was the day I stopped using it. If Linux turns out to be a problem I can always swap hard drives and resume Windows like I never left. I
    This is the video that caused me to switch to Linux. He walks you through the steps of how to do it for people not comfortable with Linux or changing Operating Systems. It's not hard at all.
    Star Rider, PacoTaco, The_vett and 4 others Thank this.
  3. Mattflat362
    Mattflat362 Road Train Member
    2,711
    6,231
    Feb 18, 2015
    Avon Lake, Ohio
    I have been back and forth will all of them over the years. I still like Win (11) with Brave for a browser.
    You can put 11 on old hardware using a tiny program called Rufus and a USB data stick. Rufus simply taps into the already existing override for the new hardware requirement (TPM on the motherboard).
    Windows is now a free dload and requires no key.
    So if you ever want to go back just dload Win 11 and Rufus and build the data stick and boot and done. Very fast process these days.
    At this point I am not even sure why I like one over another....they all get set up the same way by me and all behave identically.
    Star Rider and The_vett Thank this.
  4. tscottme
    Yes, thank you. for responding. I've also seen that a program called Tiny11 allows you to preemptively not install any of the bloatware that is built-in to Win11. I've been reading about Copilot and other AI tools that essentially are like keyloggers, as far as privacy is concerned, and decided the Win 10 end of support was enough motivation to break away from Microsoft finally. I had been using it since everything was DOS based and command-line with storage being 5.25 inch floppy drives and when hard drivers costs thousands of dollars.
    So far everything I've wanted to run on Linux I have found a version for Linux. So far, I love it. My 12+ year old laptop is like a new machine. The only downside is I haven't yet found a way to make USB hubs work with more than one USB device plugged in.
    Thanks for responding.
    Star Rider, The_vett and Mattflat362 Thank this.
  5. Mattflat362
    2,711
    6,231
    Feb 18, 2015
    Avon Lake, Ohio
    You and I have been at it from the beginning then! I really didn't get heavily interested until 98SE and Return to Castle Wolfenstein though!
    Star Rider and tscottme Thank this.
  6. Star Rider
    Star Rider Road Train Member
    1,790
    18,716
    Sep 23, 2019
    Welcome to freedom from Winblows!
    I ditched it and went to Linux completely in 2019. ( I'm still mad that they downloaded 10 on my 7 machine as an update)
    Don't limit yourself to just one distro, check out a few until you find 'the one'
    Most have a live ISO you can try from a USB stick without installing. Just create it like you did with Ubuntu and boot from it.
    Here is a link, the column on the right lists the popularity of different distros,
    DistroWatch.com: Put the fun back into computing. Use Linux, BSD.
    Ubuntu has become somewhat 'corporate' lately and I don't care for the Gnome desktop environment at all, but the cool part about most linux distros is that you can change the DE! Very cool!
    I distro hopped for a while and found they are either based on Debian or Arch. (Ubuntu is based on Debian). I just went to the source and now run Debian on my home server and desktop with xfce DE.
    For someone switching over to Linux from Winblows I would recommend Linux Mint Debian Edition, very stable, non free packages and flatpak enabled from the start.
    Any questions feel free to ask!
    tscottme Thanks this.
