I want tips for pump after resin
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by 77fib77, Aug 15, 2018.
  1. 77fib77
    77fib77 Road Train Member
    10,561
    66,319
    Jul 7, 2010
    St Louis
    OK today I had to loosen a plate on my pump to get it to turn. Mind I stood on an 18" pipe wrench and it only turned after I loosened the side plate . Last load was resin. I had it cleaned and left the caps off for 5 hours to let it air dry. Is there something I should add , like turpentine?
  3. ncdriver1
    ncdriver1 Road Train Member
    1,106
    1,252
    Dec 3, 2012
    needs caustic. whoever washed it didn't do it right. Rubbing alcohol might help. If you can put steam on it and get it nice and HOT HOT HOT and then run caustic through it should get most of the resin out.
  4. 77fib77
    10,561
    66,319
    Jul 7, 2010
    St Louis
    Is resin "dissolved " in a petroleum spirit , like paint thinner.?
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,471
    6,508
    Aug 26, 2014
  6. homeskillet
    homeskillet Road Train Member
    5,950
    44,435
    Jun 1, 2013
    Dayton, OH
    Some of them are.
    Next time you deliver resin, ask the receiver if they have the proper solvent. If you can get a five gallon bucket of solvent, put your suction and discharge hoses in the bucket and run the pump a minute or two.
    Makes things easier at the tank wash.
  7. Orange713
    Orange713 Medium Load Member
    613
    374
    Sep 14, 2013
    Houston, tx
    I just pump off resin had Dana in avenel run the pump and hoses with trailer
    77fib77 Thanks this.
  8. 77fib77
    10,561
    66,319
    Jul 7, 2010
    St Louis
    Either way I need to buy some pipe wrenches.
    Orange713 Thanks this.
  9. TheyCallMeTaterSalad
    TheyCallMeTaterSalad Light Load Member
    57
    22
    Jul 23, 2013
    New York State
    After i pump resin I put diesel in my pump and let it spin for a bit. Then when they go to clean it, makes their life easier and it stays loose. Wont harden. I leave it right in the pump untill I get it cleaned
  10. Just passing by
    Just passing by Road Train Member
    1,177
    3,140
    Feb 25, 2017
    Always remind tank wash not to use water. It will harden resin.
