I64 West through WV KY IN MO at night?
Discussion in 'Questions From New Drivers' started by CDL CPL, Oct 3, 2017.
  1. CDL CPL
    CDL CPL Light Load Member
    186
    63
    Aug 14, 2017
    Iowa
    Does anyone have anything crazy to say about I64W through those states? We fairly new drivers and like to research the trip before we head out. Anything to watch out for? Or anything to say that should be known? Thank you in advance! Anything helps!!!
  3. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,764
    Mar 9, 2014
    In a van down by the River.
    It's not a bad run till you hit West Virgina. If you are heavy the mountains will be tricky. Got stuck up there in the snow.
  4. TripleSix
    129,651
    East of Beckly, i64 has some serious pulls. It's not really hot right now, but in the summer, in high heat, with a heavy load, watch your temps. Then its toll road to charleston. And hilly all the way to Louisville, ky. Nothing dangerous, just a good workout for a driver.
    Orangees, BigBob410, MACK E-6 and 2 others Thank this.
  5. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    WV. Your brakes will get hot if you run too fast.Keep it under 50 mph downhill. Less than that if your 40k lbs I don't run over there anymore if its over 30k lbs.
    Lepton1, CDL CPL and CrappieJunkie Thank this.
  6. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    Any serious grades to look out for? We are just under 34k. Lots of tolls in which state? We going all the way from VA to St.Louis
  7. 6wheeler
    2,696
    4,774
    Aug 30, 2009
    I think its maybe like a $15 toll. Not over that. Yea I've seen a few roll overs that let the truck get away from them in WV. WV will test a truck driver. 20 miles into KY and everything becomes flat and straight. If you dont stop at the travel plaza on 77 then you might not find parking till KY.
    CDL CPL Thanks this.
  8. CrappieJunkie
    3,982
    18,764
    Mar 9, 2014
    West VA. 34k is good. Use your jakes.
  9. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    So is that the best route then? There was another that showed up through PA but looked like more big cities? Likei said before we fairly new and try to stay away from traffic..is WV really that nuts??? We dont speed or anything like that
  10. CrappieJunkie
    3,982
    18,764
    Mar 9, 2014
    It is really the best route. WV can be bad. Just stay calm. Hit all your shifting points and you will be fine. Dont go through PA.
    One other option is 77 thru VA to US 35 in WV to I 70 in OH, but it is probably longer and you will hit worse hills that way.
  11. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    The only big grade will be Sandstone like mile marker 144-138. And once you get north of Beckley between mile marker 60-73 you will not have any cell phone service, regardless of who you have. Other than Charleston, Lexington, and Louisville its a long boring ride
    Reason for edit: fixed quote
