Idea needed for receptacle/socket
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hanadarko, Apr 24, 2012.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,970
    934
    Oct 1, 2009
    Midwest
    I want to hook up a trailer air suspension dump valve and need to pigtail it like we do for the green electrical.
    I have a 1" hole next to the receptacle that the green 7way cable plugs into.
    Does anyone know if they make a socket that can mount within a 1" hole somehow and
    then I can hook a pigtail to it and duplicate to the trailer?
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Are you running elec or air dump valve air you can use some fittings similar to a shop air hose quick connect if your running elec you can buy a 4 way looks just like the7 way but half the size and only has 4 wires there commonly used to open the gates on belly dumps or running aux on end dumps and such
  4. Hanadarko
    2,970
    934
    Oct 1, 2009
    Midwest
    Electrical. Thats exactly what I am looking for...a 4way or 2way but that would mount within a 1in hole...
  5. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
  6. Heavyd
    Heavyd Road Train Member
    7,821
    6,273
    Feb 4, 2009
    Yah, that is what I was thinking too!
  7. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    Ive had the 7 pin plugs on my reefer as well as my step for quick dumps, and both are obviously bigger than one inch. You could drill it bigger and go with a ABS plug, call Badger Utility. Better yet get a 4 pin male and female from NAPA like the kind used for little RV trailers. Farm and fleet has them as well. The plug wouldnt really mount flush, rather just dangle, but the wires would fit easily thru the one inch hole.
  8. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
