Ideas on constructing a ramping device for tractor to reduce residual heel in tank?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by DELTA_V, Feb 8, 2015.
  1. DELTA_V
    DELTA_V Bobtail Member
    5
    I am looking for ideas on constructing a ramping device for the tractor drives that would be small enough to stow and would allow about a four inch lift of the drive axles to lift the front of the trailer for a more complete off load thereby reducing residual heel.
    I am am confident some experienced tanker drivers have come up with some ideas and devices which work well for this application. I would appreciate hearing from you with the construction plans and perhaps a photo or two of your creation. I don't want to try and reinvent the wheel, so to speak, if someone has a good system they have already created.
    Obviously, I am trying to avoid unhooking and building blocking under the landing gear and endless cranking :).
    Your ideas and input would be greatly appreciated.
  3. david123abc
    david123abc Heavy Load Member
    839
    784
    Feb 2, 2011
    Augusta, GA
    4x4 wood about as wide as the catwalk, cut the ends at an angle to make a ramp?
  4. Riprap
    Riprap Light Load Member
    286
    1,979
    May 31, 2014
    Saginaw, MI
    Would it be easier to drop air from trailer bags and temporarily raise leveling valve on tractor?
    baha Thanks this.
  5. Cat sdp
    Cat sdp . .
    20,981
    73,173
    Apr 8, 2012
    Orion's Belt
    Ramps sound good but end up being a big pain in the butt... And kinda hard on rears.
  6. Hammer166
    7,458
    27,031
    Aug 18, 2007
    ~8600+' and loving it!
    On carhaulers, we have a system that overlifts the airbags for increased ground clearance. It's basically a second leveling valve that is activated when an air switch is thrown in the cab. It would be perfect for the scenario you present, allowing you to lift as needed without worrying about over-inflation of the bags as you unload, as the secondary valve merely maintains a higher ride height and would bleed bag pressure as you unloaded, protecting your bags.
  7. kemosabi49
    10,663
    45,729
    Jan 13, 2013
    SW Arkansas
    I saw a guy that had ran a bypass line around the leveling valve for his tractor air bags. When he opened the valve the air bags would inflate until the shocks reached the end of their travel. It gave him 2"-3" extra height and was enough for when you get on the bad inclines, he doesn't worry about getting all of the product off. Guy said to make sure you don't forget to close valve before you leave as bad things may happen if you don't. I've brought it up to our shop guys but as I drive a company truck they won't bother with it. If I was an O/O I would do it for sure.
  8. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Tankers are usually lite on the drives anyway .......but I'm curious...why do you care about heel?
    What I did was had my 5th wheel raised professionally and then run the 24.5 on the mule with 22.5 on the trailer. The tanker got about as empty as it was going to get with this setup.
    Most of my trailers had auto suspension dumps too which helped..........so back to my first question......
  9. chalupa
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Whoops ! Better fix that before I get flamed. "tankers are usually lite on the drives" because in the past a std load would over load the drives and you can't shift liquid very well SO a smaller tires on the trailer plus and elevated 5th wheels gets you legal. Loaded drives now usually run 32/33k to the trailers 33/34 k.
    Whew.....
    Cat sdp Thanks this.
  10. QualityMike
    QualityMike Light Load Member
    288
    201
    Jun 19, 2011
    North Dakota
    6X6 ramps 18" long are a good idea. Punch a hole through the end and put a chain through to hang with your tire chains. You only need to roll up on them when you are almost empty. Takes the strain off the rear end.
  11. Cat sdp
    Cat sdp . .
    20,981
    73,173
    Apr 8, 2012
    Orion's Belt
    So you'll stop the unloading process disconnect and plug/cap hoses. Move truck 18" and reconnect and finish unloading ....... Dow and other holier than tho places will never allow it.
    like I said sounds good.... In the field not so much.
    Unless your paying a fine for the wash why bother..
    P.S. Like others have said...tell your boss to spec his equipment right. But what do I know.
    Hammer166 Thanks this.
