Idle Free APU for Mack Trucks
Discussion in 'Ask An Owner Operator' started by aTruckersgirl61, Nov 17, 2018.
  1. aTruckersgirl61
    aTruckersgirl61 Bobtail Member
    6
    Nov 17, 2018
    Hi, I am looking for an Idle Free APU for my boyfriend's Mack truck for Christmas, any advice?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Go with him and use your body heat to keep him warm through the night.
    Or buy a diesel powered unit. The battery units don't cool all that well in summer heat. If a.c. is not needed for summer operation then just get a bunk heater for about $1,200 versus a full blown apu for probably $12,000. An apu also weighs 400-500 pounds and not every state recognizes the increase in gross weight due to anti-idling equipment for driver rest periods. Don't believe the pitch about it keeping the coolant circulated and warm, if it's that cold to worry about then better to leave the big engine running. Otherwise just idle a few minutes before moving for cold starts.
    Welcome to the forum.
    SixShooterTransport Thanks this.
  4. aTruckersgirl61
    6
    Nov 17, 2018
    Ok. Thanks so much. I do go with him sometimes when Im not working and I love it.
  5. SixShooterTransport
    SixShooterTransport Light Load Member
    274
    558
    Mar 4, 2018
    I don’t know what your budget is for new vs used APUs, but you should definitely make sure you get one with a warranty. They’re quite expensive to work on and depending on what brand you get the availability of service places may be less than ideal.
    PE_T Thanks this.
  6. aTruckersgirl61
    6
    Nov 17, 2018
    Ok thanks so much.
  7. Espressolane
    17,701
    108,794
    Some questions
    What are you thinking is an APU?
    What do you want this APU to do?
    Are you wanting a factory new unit, or maybe used ?
    Is this truck the unit will be installed in, owned by your boyfriend?
  8. aTruckersgirl61
    6
    Nov 17, 2018
    I have no idea, keep him from having to idle his truck during the summer and winter months, used maybe, and yes he is an owner operator.
    Bean Jr. Thanks this.
  9. Espressolane
    17,701
    108,794
    Auxiliary power units, (APU) can be quite expensive.
    New units start about $8500 for a basic model and can go as high $15,000.00 for top line units. Takes most of a day to properly install one.
    Power source can be a small fuel fired engine or a from a battery bank system.
    Most systems will only provide cabin cooling and some electrical power. Heat is usually from a separate fuel fired heater system.
    Find more info here
  10. aTruckersgirl61
    6
    Nov 17, 2018
    Wow, ok, thanks so much for the information.
  11. aTruckersgirl61
    6
    Nov 17, 2018
    Thank you all for your tips, advice, and information.:)
