Idle issue?
Discussion in 'Kenworth Forum' started by Keegan, Jul 30, 2015.
  1. Keegan
    Keegan Bobtail Member
    Cincinnati, OH
    I have a '99 KW W-900L with a heavy duty 13 speed transmission, and a N-14 Cummins engine. What's the recommended idle? 500, 1000, something in between?
  3. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Most of the Cummins n-14 I have seen idle between 500-600 and bump up to 900-1000 when you idle it up.
    Keegan Thanks this.
  4. Keegan
    Cincinnati, OH
    What about when you're sleeping?
  5. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    I usually tell people to set it to about 900. A lot of N-14 just bump up to about 900 and you have no choice. It will go no higher and no lower. 900 range should be fine.
    Keegan Thanks this.
  6. 062
    062 Road Train Member
    6,205
    33,430
    Oct 20, 2013
    As far as dead idle,just set it for smoothest idle,no mirror shake ect. If you turn on the pto function in the ECM,then it will high idle what ever you want,but 900 should be default.
