Idle Shutdown Help
Discussion in 'Questions From New Drivers' started by arewethereyet1, Aug 23, 2014.
  1. arewethereyet1
    arewethereyet1 Light Load Member
    205
    27
    Feb 1, 2014
    2011 Volvo. Idle shutdown occurs after about 15 mins. Any tips to bypass?!
    Thanks!!!
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Only pull the red button out while you park. Give that a shot. Could also try setting the cruise, sometimes that disables auto shutdown. Maybe rest something against the clutch just enough to push the switch. Or the fuel pedal just a touch down. Anything to trick the ECM will do it. Or you could somehow get the ECM setting changed ....................
  4. arewethereyet1
    205
    27
    Feb 1, 2014
    Currently have a stick wedged between the seat and fuel pedal :)
  5. MsJamie
    MsJamie Road Train Member
    In my 2013 Volvo, when the Idle Shutdown light/message comes up (about 30 seconds before shutdown), depressing either the brake or clutch pedal for about a second will disable the shutdown, and the display will indicate so.
    If I move the truck more than about 10 feet, the shutdown will reset, and I have to do the bypass again.
    Your company may have had the computer programmed to not allow a bypass, or use something else.
  6. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    What is this red button you speak of?
  7. BrenYoda883
    BrenYoda883 Road Train Member
    1,248
    1,422
    Sep 18, 2013
    One thing to consider. .. some companies frown upon bypassing the idle shutdown... and if you are on qualcomm or some e log that also tracks performance then they will know you are bypassing it in some manner...
    We have had drivers placed on a safety hold and had to get with safety and written up for bypassing the idle shutdown. ..
    I know that is the summer if I park my trucks fro t end close to a building or to the trailer in front of me the heat of the engine against the trailer or building will make the temperature read high enough so the idle shut down does not occure...
  8. Figgy
    Figgy Light Load Member
    52
    17
    Jun 19, 2012
    southeast regional
    When message pops up on dash. Press cruise controll button up up down and it will turn idle shut off off
  9. kidsdad
    kidsdad Medium Load Member
    327
    298
    Nov 11, 2010
    central illinois
    He means to set the trailer brakes only, while leaving the tractor brakes released.
    b
  10. Chewey
    Chewey Light Load Member
    140
    72
    Feb 10, 2012
    Set the trailer brakes then hit the cruise control to idle it up. Be warned though; if you have a regen engine, idling will cause the egr valve to clog up and the regen system will be working over time.
  11. Pahrump
    Pahrump Medium Load Member
    if it is your truck you can get the ECM reprogrammed to idle more,, if a company truck check with them,
