I have a truck that shuts off after 5 minutes if the truck doesn't move. Tapping the gas doesn't reset the timer. I have to move 2-3mph. Let's say there's a bad accident and I'm in standstill traffic and can't move. The truck will shut off. How would I keep from rolling backwards without setting my brakes? If I hold the brakes with the engine off it'll eventually deplete the air since the compressor isn't running. Setting tractor brakes and putting in neutral on a steep hill with a heavy load doesn't feel right
idle shutoff question
Discussion in 'Experienced Truckers' Advice' started by Jenkins2020, Oct 21, 2022.
Holding the pedal should NOT deplete your air supply. If it does you have a leak. It's a closed system basically, when you apply brake pedal to fills brake chamber. Should hold pressure.
I'd just set the brakes after 5 minutesBean Jr., God prefers Diesels, Oxbow and 3 others Thank this. -
Try your hand brake, our trucks auto shutoff also. We can hit the accelerator or pull the hand brake for a second. Some of our trucks tapping the accelerator doesnt work and you have to put your foot in it for a second.
If i was in standstill traffic for a extended amount of time. Id just set the brakes, hazards on and pull hand brakes when truck tries to shutdown. Or just shut the truck off if i didnt need heat or air conditioning.Grubby#1, tscottme and Jenkins2020 Thank this. -
You're not going to deplete the air. Once you fill up the chambers that's it, nowhere else for the air to go.
Unless of course you have a major air leak, in which case the park brakes would automatically apply once the pressure gets low enough.
Modern air brakes have so many failsafes built in that its extremely rare to have a total brake system failure.Grubby#1, Bean Jr., tscottme and 1 other person Thank this. -
I see. Thanks, I swear I saw my air pressure drop a bit while in traffic one time so it must've just been an airleak in the past. Good to finally have clarification on that
Pushing down and letting up will cause air to drain. -
You could always ask them what's cheaper, a gallon of diesel or a starter.
