Idling fuel consumption at 900rpms 2023 Freightliner
Discussion in 'Questions From New Drivers' started by John_B, Sep 20, 2023.
  1. John_B
    John_B Bobtail Member
    8
    Sep 1, 2023
    2023 freightliner Cascading DD15 Gen 5 14.8 liters.
    My question is how much fuel is used if you idle at 900 rpm’s. Now I see people say it’s a gallon per hour but I don’t think rpm’s and type of engine was factor into that. I believe that every truck is different so that 1 gallon per hour I wouldn’t think is the minimum standards. Let me know!
  3. Long FLD
    Long FLD Road Train Member
    11,577
    47,104
    Mar 4, 2015
    2022 579 with the MX13 and idling at 700 mine says .7 gallons per hour. If it’s cold and it’s idling at 1000 it usually says 1 to 1.2 gallons per hour. When it’s at 1000 with a load on the engine to warm the dpf it says 2 gallons per hour but the warmup only lasts 30 minutes.
  4. tscottme
    tscottme Road Train Member
    My Volvos, several different ones, showed an idle fuel consumption around 1/3 gallon per hour. I think my 2020 KW T680 with big inverter showed around 0.5 - 0.7 gph at idle. 1 gph is probably the high-end of estimates, not the low-end. Manufacturers have seen tehir customers care about MPG for decades, there is not going to be a wide difference between most trucks. The trucks that are specced to drag a battleship up Pike's Peak or for 12 MPG are not going to be the same but 90% of trucks will be very close.
  5. drivingmissdaisy
    drivingmissdaisy Road Train Member
    1,947
    3,311
    Jun 10, 2019
    Even at only 1gph, if you sit for a 10 hour break you are tossing 45 dollars a night out of the window.
    jimbo33, flood, Bean Jr. and 3 others Thank this.
  6. Long FLD
    11,577
    47,104
    Mar 4, 2015
    That’s the beauty of buying my own fuel. I can decide if I want to be comfortable or not. However very rarely do I idle for the entire night and that’s part if the reason why I can’t pencil out spending $15k for an APU.
    kanidana, 88 Alpha, Oxbow and 7 others Thank this.
  7. tscottme
    Or spending money to prevent the driver not crushing 4 wheelers due to fatigue.
  8. AModelCat
    156,289
    How much does a call to boost a frozen truck cost?
    tscottme, RockinChair, Cat sdp and 7 others Thank this.
  9. Short Fuse EOD
    2,766
    8,623
    Jul 29, 2015
    Midwest
    I agree with you on that one. I won’t buy one. By the time I make it pay for itself it’ll probably need to be rebuilt. Helps to work in the Midwest often where it can cools off at night.
    Oxbow, lester, cke and 3 others Thank this.
  10. Last Call
    Last Call Road Train Member
    7,568
    45,898
    Mar 15, 2021
    Have you priced a APU lately ? And I have my doubts you burn much more than .5 gph so thats 22.50 for ten hrs
    Speedy356, Oxbow, cke and 1 other person Thank this.
  11. kemosabi49
    10,491
    44,744
    Jan 13, 2013
    SW Arkansas
    Nice thing about being a company driver. Fuel doesn't cost me a cent. Though I don't idle if I can get my rest without it.
