Idling to charge dead batteries
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Disturbed Canuck, Aug 15, 2009.
  1. Disturbed Canuck
    Disturbed Canuck Light Load Member
    111
    5
    Mar 13, 2008
    Saskatoon, SK
    Hey folks.
    I'm trying to satisfy my curiosity here. Some weeks ago, I left my cooler on over the weekend when I was parked and kapuff, my batteries died. Instead of paying for an expensive funeral, I called up the revival specialists and for a mere $30, my batteries came back to life thanks to the holy tow truck. Everything has been fine and dandy since then and I went out to cruise on down the road but I was thinking of something ever since that happened.
    If I had gotten it boosted with another couple of days to sit and say I wanted to run things like my laptop and keep the power inverter going, how long would I have to idle every day to bring my four batteries to a full charge? I guess since I end up idling every so often when it's hot, I've never actually had to worry about this and have just ended up idling a bunch anyway 'cause who wants to sit in a hot parking lot for three days boiling in the bunk?
    But yeah...any idea what the average is for charging four average batteries at idle?
    Cheers
  3. northern flight
    northern flight Bobtail Member
    41
    May 11, 2007
    Canada
    I would think you have to drive it.You may have to bring it up to road speed like 30 to 60 mph for roughly half hour of driving in order to keep your batteries properly charged up just as if it was a car..this is something i would do..but thats just me here..it always worked for me though.
  4. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    high idle should do it
  5. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    I can't give you any "professional" numbers.
    But I can tell you what I done to take care of this issue.
    I fired my truck up for 30 minutes, every 48 hours. If it was extremely hot during that period, I would do it within 36 hours. I allows bumped the idle up to about 800 rpm.
    This worked fine for me, even when I took as much as 7 days off.
  6. 05chopper
    05chopper Light Load Member
    169
    22
    Dec 25, 2008
    USA
    YOU said I 'm trying to satisfy my curiosity here. Some weeks ago, I left my cooler on over the weekend when I was parked and kapuff, my batteries died. Instead of paying for an expensive funeral, I called up the revival specialists and for a mere $30, my batteries came back to life thanks to the holy tow truck. MY 2CENTS If you charged the batteries with your alternator from a jump start then expect to have an early death to your alternator from overheat.
  7. Jim Bob
    Jim Bob Light Load Member
    183
    50
    Aug 2, 2009
    Portland, Or
    Well if you have a total of 1000 amps worth of batteries. You want them to live more than a few months so you can only drain them to 75%, which would be about 9,000 watts that you could use. But you cant, because a battery takes forever to charge to 100%, so you can only use about 5,000 watts of power before you need to recharge.
    Your alternator will probably put out a maximum of 600 watts at idle unless you upgrade it. So you would have to idle it for 8 to 10 hours a day.
    Of course you could idle it for less and draw more electricity, but what you save in fuel will only cost you in replacement batteries.
  8. lowbudget
    lowbudget Medium Load Member
    428
    110
    Apr 12, 2008
    Bismarck, ND
    just 1000 amps? in a Big Truck? hell, I had a 1000 CCA battery in my 1968 F-100.
  9. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    What Jim Bob said....:yes2557:
