Idling with a Big Cam Cummins
Discussion in 'Experienced Truckers' Advice' started by OldeSkool, Jun 3, 2019.
  1. OldeSkool
    OldeSkool Road Train Member
    2,145
    7,110
    Jul 17, 2018
    New Hampshire
    I have a dream of buying my next truck and learning to know it like the back of my hand. I've been thinking about a Pete 359 for a while, (wife says it has to be a Pete) with a big cam cummins for a fairly simple easy to work on truck.
    I've read many posts on here about them and I keep reading they don't last if you idle a lot. I idle all the time since I haul into local mills and wait in line. Should I give up the big cam dream?
    Rideandrepair and OLDSKOOLERnWV Thank this.
  3. starmac
    starmac Road Train Member
    6,639
    12,529
    Apr 11, 2019
    Fairbanks Ak
    Jesus, we never shut down the old big cam, small too for that matter in the winter. Idle away.
  4. spyder7723
    spyder7723 Road Train Member
    15,468
    25,078
    Mar 31, 2013
    sarasota, fl
    Good luck finding a 359 that isn't a ragged out pos for under a hundred grand. Add 25k minimum of its numbered.
    Do yourself a favor and expand your search for a 379 with a 3506, n14, or 12.7.
  5. starmac
    6,639
    12,529
    Apr 11, 2019
    Fairbanks Ak
    Lordy. I can show you several 359's local here that is far from ragged, even one 87 numbered extended hood for way under 100 grand.
    A friend just sold one that ran good, but did need a little love with a 3408 in it.
    Grubby, Rideandrepair, KB3MMX and 4 others Thank this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Take her up to 1100 with a stick on the fuel pedal on the dash She will settle down and generate zzzz in happy form. Never you mind those old wives stories about tired trucks.
    When it's below -20 put a winter front on her. She gets chilly and arthritis and cannot hardly get working good.
  7. OldeSkool
    2,145
    7,110
    Jul 17, 2018
    New Hampshire
    Lol thanks buddy. You always make me smile.
  8. starmac
    6,639
    12,529
    Apr 11, 2019
    Fairbanks Ak
    There are quite a few around with 3406's too, I would not turn one of them down if looking for an old truck. That is as long as it is a B model, I wouldn't spend much on an A or a 1693.
    Rideandrepair and x1Heavy Thank this.
  9. 201
    201 Road Train Member
    12,926
    26,611
    Apr 16, 2014
    high plains colorado
    In all my trucking, I'd say with confidence, 85% of the motors were BC 's. Idling isn't going to hurt them, they use about a gallon/hour. Bosses hated idling, because the truck gets 0 miles per gallon, but the way I figured, it was a lot cheaper than a service call. Step it up to 1000, and idle all weekend if need be. The biggest issue when cold, is keeping the temp up. I believe cold diesels, like under 140 cause the oil to break down.
    The 359 is the bigger challenge. They are out there, but owners are reluctant to get rid of them, because they won't find another. The ones that aren't being used are pretty ragged. 379's are a much easier find, and are just as nice. Cat motors are great, but can't beat a Cummins, big or small cam for simplicity.
  10. starmac
    6,639
    12,529
    Apr 11, 2019
    Fairbanks Ak
    cummins are simple, and cheaper parts than cats, they just ain't a cat. lol
    In all reality a 379 is nicer than a 359, as far as I am concerned, but again, it just ain't a 359. lol
    I prefer the old KW's myself, but if I had to go short hood with a 359 I would prefer a 379 instead, I'm thinking.
    I would love to find an old extended hood A model, I have several A models but the extended hoods are somewhat rare, and no one makes a replacement hood for them either. I am going to look into what it takes to make one an extended cowl truck, instead of hood.
  11. Dino soar
    Dino soar Road Train Member
    4,834
    27,113
    Dec 8, 2017
    I'm not a Peterbilt guy, but I am a big cam Cummins guy. You have the right idea. I would let worry less about what kind of truck it is as long as it has that big cam Cummins in it.
    Once you've had one for a while, you'll look at all the threads in the mechanics Forum about fault codes and expensive injectors and wiring and computer problems, and you'll just smile and shake your head...
