if a truck loses power steering and air at the same time...
Discussion in 'Questions From New Drivers' started by KristinTeam, Apr 19, 2017.
  1. KristinTeam
    KristinTeam Bobtail Member
    15
    Mar 6, 2016
    what would be the most likely cause of this scenario?
    additional symptoms prior to complete loss of power steering and air loss: squealing at high idle (over 15k rpm) and extremely slow air pressure build up. A/C blowing hot air.
    is this a pump gone bad or air compressor gone bad?
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
  4. KristinTeam
    15
    Mar 6, 2016
  5. Roberts450
    2,237
    3,636
    Feb 6, 2016
    Not sure on that engine but it sounds like a belt is slipping if its squealing.
    ncmickey Thanks this.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,828
    Sep 10, 2010
    Flint, MI
    That's what I was thinking. Idler pulley is trying to freeze up, or even another pulley (ac clutch) is freezing.
  7. AModelCat
    159,114
    If you're running at 15,000 RPM I think you've got more to worry about than no power steering.....
    All kidding aside, I'm not at all familliar with Mercedes but I have not seen a belt driven air compressor before. Could it possibly be a broken accessory drive if it also supplies power to a pulley to drive the A/C compressor?
    OLDSKOOLERnWV, SingingWolf and ChaoSS Thank this.
  8. Cornbinder_King
    Cornbinder_King Light Load Member
    176
    237
    Mar 29, 2017
    Is you power steering air by chance?
    Based on what you are describing, I would say belt is stretched beyond its service life. Or your idler pulley spring is weak.
  9. Ridgeline
    22,400
    116,455
  10. KristinTeam
    15
    Mar 6, 2016
  11. kemosabi49
    10,663
    45,726
    Jan 13, 2013
    SW Arkansas
    I driven a lot of miles with a Mercedez and the air compressor is not belt driven. The A/C is like any other truck, so if the compressor freezes up and the compressor clutch is engaged it would squeal unil the belt burned up.
