If I finish 3 hours SB on this log will it pause?
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by RunningAces, Oct 31, 2020.
  1. RunningAces
    RunningAces Road Train Member
    1,298
    2,577
    Jul 2, 2017
    On the log i posted if I finish off the 3 hours in SB time will it pause my 14 from the time I went in SB?
  3. Qbf594
    Qbf594 Road Train Member
    1,642
    8,715
    Aug 15, 2019
    Southern Canadian annex, NY
    since you already have the 9 in SB previously I think the 5 min off duty plus the almost 2 SB would be the 8 SB/ 2 Off duty to pause your 14
    RunningAces Thanks this.
  4. Brandt
    Brandt Road Train Member
    4,595
    6,309
    Sep 17, 2012
    2 or 3 hours in sleeper should pause the 14 hour clock. Do you update Keeptruckin. It should let you see your new split sleeper HOS availability after 2 hours. You just click on the box and it will show HOS availability using split sleeper.
    RunningAces, Wasted Thyme and baha Thank this.
  5. Brandt
    4,595
    6,309
    Sep 17, 2012
    Here is my original 14 clock after sitting 1:59 hours
    At 2 hours I could keep driving if I wanted to and click box and do split sleeper. It's probably not the best example because it's the end of my driving day. It did extend my 14 hour shift
    tlalokay and RunningAces Thank this.
  6. tlalokay
    tlalokay Medium Load Member
    473
    773
    Jun 3, 2014
    El Paso, TX
    I am digging the split-sleeper clock option on the KeepTruckin App.
