If I put water in my sand blower to un clog it will it damage it
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Shiney Gillz, Dec 1, 2018.
  1. Shiney Gillz
    Shiney Gillz Bobtail Member
    Dec 1, 2018
    I did a return and barite got in my blower my friend wants to put water I heard water would damage it what can I do
  3. Ruthless
    Ruthless Road Train Member
    8,948
    88,124
    Aug 28, 2010
    The City.
  4. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Lol, I have no idea.
    Is the sand in the air canister coming off the blower or the blower itself? If it got in the blower housing, I'm fairly certain it's screwed. That is a precisely machined set of parts and sand will have destroyed it.
  5. Western flyer
    Western flyer Road Train Member
    2,807
    6,796
    Mar 13, 2014
    Wd-40.
    It Works for everything else,
    but don't blame me if it blows up.
  6. REO6205
    REO6205 Road Train Member
    13,172
    60,500
    Feb 15, 2014
    California.
    What @Zeviander said. I don't know anything about Barite but I've seen pumps destroyed by sand and cement..
    Can you get somewhere to pull the pump down to clean it and inspect?
    Rugerfan and 25(2)+2 Thank this.
  7. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    If you're talking about putting water in the blower (as illustrated above), that's a stunningly bad idea. Aside from the blower not designed for it, water is an incompressible fluid (as opposed to air), and you'll no doubt break something... like the case, or a shaft, or...
  8. Shiney Gillz
    Dec 1, 2018
    Thanks everyone it was really my friend who posted it he wanted to us water I told him no but honestly thanks
    25(2)+2 Thanks this.
  9. REO6205
    13,172
    60,500
    Feb 15, 2014
    California.
    Thanks for letting us know.
  10. REO6205
    13,172
    60,500
    Feb 15, 2014
    California.
    Bad advice. Real bad.
    MagnumaMoose Thanks this.
  11. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    If you had a working check valve, the product would have never made it upstream to the blower. But once it’s in there, there’s not a whole lot you can do. Will it turn? If not, you might try pulling the burnout plug and see if you can get enough product out the bottom to make it turn. If that doesn’t work it probably needs taken apart. But do NOT put water in it. Or anything else.
    And replace that check valve man. Don’t want this happening again.
