If you apply for Crete Dry Van....
Discussion in 'Crete' started by wd40, Jan 6, 2014.
  1. wd40
    wd40 Light Load Member
    241
    116
    Nov 8, 2013
    1. Are you required to pull refer?
    2. Can you work dry van only from the Knoxville, Tn. Terminal?
  3. xlsdraw
    xlsdraw Road Train Member
    4,228
    7,299
    Nov 17, 2010
    Lake Alfred, Florida
    Been with Crete since March. Only couple reefer trailers I've pulled were dry loads. I wouldn't sweat either question if I were you. I honestly can't give you a 100% certain answer to either question.
  4. Olympian
    Olympian Medium Load Member
    334
    169
    Jun 21, 2013
    No. Crete is dry van only. If you want to pull a reefer, you can apply to go to work for Shaffer, which is a division of Crete.
    If you are hired by Crete, you will pull dry vans only no matter which terminal is your assigned home terminal.
  5. wd40
    241
    116
    Nov 8, 2013
    I want to H&W team dry van... I live in knoxville Tn. I'm not sure if the terminal here includes dry van... I was under the impression it is Shaffer terminal.... I want to avoid refer.
  6. xlsdraw
    4,228
    7,299
    Nov 17, 2010
    It is both Crete and Shaffer. As far as I know, all terminals are both. But as a team, wouldn't reefer maximize a teams potential?
  7. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    I been here 5 years, pulled a reefer with dry freight once and one time I repowered a reefer load with the heater on so the freight wouldn't freeze.
    xlsdraw Thanks this.
