If you will be driving an empty bus that weighs >26k lbs, do you still need the P endorsement?Drivin
Discussion in 'Questions From New Drivers' started by NY2001, Mar 23, 2025.
  1. NY2001
    NY2001 Light Load Member
    65
    56
    Sep 22, 2019
    I have a CDL Class A, but I don't have the passenger (P) endorsement, and I will not be transporting passengers do you still need the P endorsement regardless, or only when there are actual passengers on the bus?
  3. tarmadilo
    tarmadilo Road Train Member
    1,715
    4,716
    Dec 12, 2018
    You’d think that you wouldn’t, but I once got a ticket for driving an empty school bus without the school bus endorsement (back when that was still a thing in Maryland, not sure if it is anymore).
    nextgentrucker Thanks this.
  4. Moose1958
    Moose1958 Road Train Member
    15,257
    33,809
    Dec 17, 2010
    Williesburg, Virignia
    Let's look at what Part 383 says.
    Commercial motor vehicle (CMV) means a motor vehicle or combination of motor vehicles used in commerce to transport passengers or property if the motor vehicle is a—
    (1) Combination Vehicle (Group A)—having a gross combination weight rating or gross combination weight of 11,794 kilograms or more (26,001 pounds or more), whichever is greater, inclusive of a towed unit(s) with a gross vehicle weight rating or gross vehicle weight of more than 4,536 kilograms (10,000 pounds), whichever is greater; or
    (2) Heavy Straight Vehicle (Group B)—having a gross vehicle weight rating or gross vehicle weight of 11,794 or more kilograms (26,001 pounds or more), whichever is greater; or
    (3) Small Vehicle (Group C) that does not meet Group A or B requirements but that either—
    (i) Is designed to transport 16 or more passengers, including the driver; or
    (ii) Is of any size and is used in the transportation of hazardous materials as defined in this section.
    It does seem counterintuitive, but what defines a CDL-required CMV is not how it is loaded, but what it is designed to carry howbeit that load be weight or passengers.
  5. Ridgeline
    22,603
    120,016
    What kind of bus, and what are you doing?
    these are the two most important questions.
    weight has nothing to do with it.
  6. roundhouse
    roundhouse Road Train Member
    3,191
    7,257
    Jul 11, 2018
    Weight doesn’t factor with busses
    I always thought it was the passengers seating .
    Seating for more than 15 passengers triggers the P endorsement is the way I understand it
    the passenger endorsement is easy to get
    pass the written test and the parking lot pre trip test and then pass the driving test .
    I helped lots of people get the P license for my church .
    Most of em had issues passing the pre trip exam in the parking lot
    don’t think I ever had anyone fail it more than once though
  7. Ridgeline
    22,603
    120,016
    There is another factor, transporting a school bus without passengers requires a P but not an S endorsement.
  8. roundhouse
    3,191
    7,257
    Jul 11, 2018
    Oh yeah
    I forgot about the S
  9. tscottme
    tscottme Road Train Member
    The actual weight & passenger count isn't the deciding factor. The maximum weight/passenger capability decided by the factory is what counts.
