Ifta audit
Discussion in 'Trucker Taxes and Truck Financing' started by ela, Jun 20, 2014.
  1. ela
    ela Light Load Member
    64
    9
    Jan 22, 2013
    Hello all,
    We are having an Ifta audit in NY. I have all the fuel receipts, bol, repair invoices, and details on all the loads hauled. Problem is I don't have logbooks, and odometer readings.
    How bad is the situation and what do you advise?
    For those who have had an ifta audit, how long does it take, and how much have you been fined?
    Thanks
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    You don't have logs of mileage for each state? How are you filing ifta without that?
    RedForeman Thanks this.
  4. ela
    64
    9
    Jan 22, 2013
    Some quarters I have used the mileage from the gps (which calculates ifta miles for each jurisdiction).
    Some quarters I have used the bol for origin and destinations and fuel receipts, and used the ifta software like trucking office to put these info in.
  5. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    2,500.00$ fine have report of fire ready at audit?
  6. ela
    64
    9
    Jan 22, 2013
    Report of fire? What do you mean?
  7. baha
    4,137
    2,836
    Jul 25, 2013
    ga
    The one that smoked all the MI. by state rec.you should have,start putting them off and make new logs and mi by state with bill of trips you have del. when the audit started they opened door punched in MI. on od. an started in rev. one load that paid 107 hub mi run guntersville al. to EX. 5 on I-20 GA. they came up with going over 100mi. extra I-59 N. to chatt. tn. SO. hy27 down to ex. 5 useing their truck route plan, got out paper map and showed AL hy 58e to 9so. to hy278E over sand MT. 2 lane hy all the time. they CK. all MI. and some drivers were out of line, 2thousand5hundred later and have not been back after6yrs.
  8. ela
    64
    9
    Jan 22, 2013
    How many quarters did they audit you? How long dot it take? Thanks for the input.
  9. baha
    4,137
    2,836
    Jul 25, 2013
    ga
    1Quarter took about 2hrs 16 trucks,start now and put it off so you can (get papers together) I had cert. mail telling when to make all logs MI. by state fuel rec.,they look at logs only to ck. each state mi. the bad part is they are ck. for all other st. in irp. so they think they are low paid but powerfull?
  10. ela
    64
    9
    Jan 22, 2013
    They want to audit 3 years, that's what it says on the leter.
  11. jbatmick
    jbatmick Road Train Member
    2,196
    2,459
    Dec 1, 2009
    hastings, Fl
    If the IRS can lose the E-mails that Congress demanded and not produce them,then we should be able to use the same arguement.
    Excorcist1 Thanks this.
